ABS light, trans in limp mode
Ok I changed the oil in the differential...seemed as though it was fixed as the O/D light stopped flashing....then the motor started stalling at low RPMs and then the O/D light started flashing again so I ran diagnostics again and it came up with CPS code Imagine that huh? They should sell cases of those damn things....the 7.3 seems to eat cam position sensors. So I quess thats what I will be doing this morning is changing that out, wouldnt be so bad if it wasnt in such a bad spot
Well, Mark, you are certainly a ray of sunshine this morning...Thanks for your obviously professional input however. If you were a Ford Transmission engineer I suppose you know more about what your talking about than most.. But a little heads-up on what the correct hardware/software is would be helpful. To be honest, I am in fairly dire financial straits right now, and cannot afford to have the thing towed to the dealership, and then pay them an exhorbitant fee for 10 minutes work. It is like going to your general practitioner so he can charge you $100 to tell you to go to a specialist... Can you tell me what scanner/software we have to use so I don't just go around pissing money away on people who cannot help me?
You can tow in overdrive all you want as long as you keep your temperatures in control. I do all the time.
As far as pulling the codes, you need AE software, aeroforce scangauge, or snapon with capabilities to work with the psd. If you know someone with a superchips programmer for a psd, you can pull the codes with that also. Or like mentioned a good trans shop should be able to pull them.
Finally got scanner to work. Apparently some poor connections on the battery were keeping the scanner from getting full power. I replaced the cables and ends and then scanned again. Got a PCM code..Believe it or not, un-hooking and then reconnecting the PCM appears to have fixed the problem...make any sense?
You can if you're into randomly replacing parts. Why do you think the PCM is the problem? I think you need to do some diagnostics to determine what's wrong. It is unlikely that the PCM is the problem.
Sometimes the cheapest way to fix a problem is to take it to a professional that know what he is doing.
No Mark, I am not into randomly replacing parts at all. The scanner, according to my neighbor the mechanic who was reading the thing, tells us it's the PCM..I am not 100% sure however that he is reading the thing correctly. Should there actually be an alpha-numeric or other type of code given? I mean I haven't even looked at the display on the scanner. This is all new stuff to me..I have owned this rig for 7 years, and this is the only major issue I have had with it.. Prior to that my F-150 which I never had an issue with, and prior to that, it was rigs without computers on board! Gotta luv technology...
#28
#29
