Fusible link for trailer lights and brakes?
I was just drivign along with my trailer lights/brakes working fine, then, I started the truck again and noticed no lights or brakes on the trailer, though lights were working fine on my truck. I tried finding the fuse but all I get is, it seems there is a fuse for the trailer lights, and another for trailer brakes, somewhere near the starter relay, both 20 amps. I can only find one yellow wire leading to the relay with a fuse, and it's a 30 amp, and it looks just fine.
Any suggestions?
Any suggestions?
Sounds like you lost the ground to the trailer.
Anyway it is Fuse Link "G" coming off the starter relay on the passenger fender for the marker lights on the trailer. Fuse link "G" feeds the relay for the marker lamps. It is 20GA Blue and not 20 Amps feeding the yellow wire.
The brake lights are fused in the fuse box on the safety wall in the cab. But if your brake lights work on the truck then fuse #1 is OK.
For whatever reason, I'm not allowed to post attachments, so i can't post the picture I took. But I looked all over the engine compartment and I cannot find a fuse panel. Where would it be? It's a 91 F250, 460.
However, I did look around the starter relay and notice a bunch of small blue wires around the battery that get fed into a yellow wire that has fuse links in it. One of these blue wires was completely burnt and disconnected. Could that be it? I did notice a little bit of burning smell when driving it last but couldn't tell if it was someone else's car, and it didn't last long. This wire may have been burnt for a very long time.
Nothing was working on the trailer at all. No light, no brakes. Also, I knew it was the truck causing the problems because I took a test light to the trailer-plug in at the back of the truck, and I wasn't getting any juice to any of the contacts. I also lost my blinkers on the truck.
So what I did was go get a new flasher. Turn signals still didn't work. Then I put another fusible Link where the wire burnt up. I was now getting electricity to one of the contacts at the trailer hook-up. Progress. But still no turn signals. So, I looked, and the fuse under the dash, for the turn signals was shot. Then, I noticed I had no brake lights (though I did have them yesterday even after my trailer lights stopped working). So I found out that fuse was bad too and replaced it.
I'm pretty sure my trailer lights are going to work again, but concerned I have electrical gremlins on the truck, if I'm blowing fuses.
silentrunning
02-24-2012 06:20 AM
