Up Pipes And Non EPV exhaust Outlet
Its all personal preference but if you want them to hold up cosmeticly a good ceramic high heat application would be nice not to mention some other benefits, reduced heat transfer and better spool up, read off of Clay's site.. Clay at RiffRaff performance diesel here offers that option when you buy his uppies.
And as far as preference goes, I just prefer that they dont rust and I also prefer not to waist my time painting them if its just going to fail.
I wonder if its just the tubing that get ceramic coated or the whole assembly.
I read that before I ordered mine. $100+ for ceramic coating is way to rich for my blood.
[quote=endobear;11613975]
I painted the up-pipes, collector and the turbine housing.
A little cleaner than this!
I have used VHT FlameProof paint on my up & down pipes, baby butt collector and turbine housing. It has silica and ceramic in it VHT FlameProof™ Coating Also on my down pipe I have it wrapped. I am going to also wrap up pipes after welding in bellows and painting with the VHT FlameProof. And this stuff has to be cured in a special way to work correctly as you can see in that add. But I always paint before wrapping for 2 reasons 1: to help keep them from rusting 2: To help hold the wrap in place and hold more heat in. Just my 2 cents.
Ken what kind of paint did you use?
