6.2L V8 Discuss the 6.2L V8
Factory 6.2 Internals.
Old 12-06-2011, 02:59 PM
N7Quarian's Avatar
N7Quarian
N7Quarian is offline
Question Factory 6.2 Internals.
What are they? Forged? Cast Iron?
Old 12-06-2011, 03:19 PM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
A little bit of everything..
The 6.2 engineer answered a bunch of questions in this thread:
https://www.ford-trucks.com/forums/9...as-engine.html
Details of the motor:
2011 FORD SUPER DUTY BOASTS 6.2-LITER GAS ENGINE .: News
Key features of the new 6.2-liter V-8 gasoline engine include:
*Cast-iron engine block and four-bolt main bearing caps, with cross bolts, for durability
*Aluminum cylinder heads, with two valves per cylinder and two spark plugs per cylinder
*Cast-iron crankshaft, with dual-mode damper
*Forged steel connecting rods
*Cast-aluminum pistons, with cooling jets
*Single overhead camshaft with variable valve timing and roller-rocker shaft valvetrain
*Magnesium cam covers for lighter weight
*Stamped-steel oil pan
*Composite intake manifold
*Stainless-steel fuel rail; port-fuel-injected; mechanical returnless fuel system
*9.8:1 compression ratio
*E85/flex fuel capable
mmuenchow
06-16-2006 11:35 PM
S.WHITNEY
01-17-2006 08:47 AM
mudvilles9
10-23-2003 12:54 PM
Justme
09-12-2003 02:46 PM
89Bronco_EddieBauer
1978 - 1996 Big Bronco
04-27-2003 02:37 PM
Quick Reply: Factory 6.2 Internals.
