weight scales
weight scales
Ok, would like to weigh my truck but not sure what to expect. On my highway exit there is a flying J and a pilot and I beleive they both have a sign up for certified scales. I haul firewood quite a lot, and unsure of if I'm actually overweight, I'm pretty sure I am. Also the trailer too. I got in late last night from the farm, fully loaded still, thinking I might drive it to the scales before I unload it to check, then go back later after its empty to get a base weight.
So whats to expect? Are they like self service or do you have to go into somewhere... I hate feeling like I'm an idiot the first time I do things lol.
Plus if I am overweight maybe it would go a ways to convince the wife to let me get a bigger trailer.
Scales
Never tried Flying J but last truck stop scales I used had me drive on the scales before I went in to collect report.
I remember that they asked me if I wanted certifyed report or not. I didn't so they didn't charge me. Only charged if the report had to be certified. Just had me drive on the scales, gave me the numbers over the CB and off I went.
We used CB to communicate. I don't remember what channel they were on. Probably 19.
How about calling them on your cell phone.
Don't worry about being over weight. They don't care and don't report it.
How much do you think you weigh?
I remember being surprised how much my F350 weighed. It think it ran about 7.5K lbs empty.
CAT scales are the most common. Pull around to the scale, put front axle on the front pad and rear on the back pad. Punch the intercom button, give them your truck number (whatever suits you), go inside pay $15 and get your weight ticket. Do this with a full tank of fuel and you for a baseline. (we carry this in each of the fleet), then repeat the process loaded.
I know I have hauled around 6000 in the bed when I hauled landscape stones and it was pretty much touching the bumpstops even sitting level. That was too much. This last trip I had two fingers between the bump stops, I'm guessing ~4,000#. But I'm more worried about the trailer. Its built heavy, but only 3500# axles. Weighs about 1400# so only about 1 ton capacity. I think the tires are just load range C and they tend to get warm. I limit highway speeds to 55. I want to either upgrade the axle on the trailer or get a bigger trailer to get brakes too. A 3500# trailer is no biggie for the truck but when its loaded and the truck is loaded I figure I'm pulling an extra 7-9k with no extra brakes. The truck seemed to brake just fine with this load but I know its hard on the brakes. Priced out an new 5k axle w/ brakes, new wheels and tires, and I might as well buy a used car hauler style trailer or something like that.
I assume I can also include the trailer on the scales?
You can weigh it all.
Go to the truck stop of your choice when they aren't busy, and you will be all set. Most I have been to are very friendly and helpful.
We use several and have base weight tickets with and without snow gear. Better to know than to wonder......
As for GVWR, should be on the door pillar.
I really do want to get brakes. Just got to convince the other half to let me buy a bigger trailer. Edited: I did just look up ohio revised code laws and found it did say trailers 2k empty or more must have brakes. I have no idea why they would care about empty weight and not loaded, who knows, but I guess I'm good there.
Here you go, Ohio requires brakes on any trailer with an empty weight over 2000 lbs.
http://drivinglaws.aaa.com/laws/trailer-brakes/
