4.6 liter install in 53-56 F100 anyone do it?
Old 03-14-2012, 12:14 PM
Crazydan's Avatar
Crazydan
Crazydan is offline
I purchased a 1998 Lincoln Cont, 4.6 liter auto trans to in stall in my 56 f100, any sugestoins?
Old 03-14-2012, 01:15 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
working on one myself.. I promised to document the stock harness wire mods.
here is that topic
https://www.ford-trucks.com/forums/1...l#post11427692
I haven't made any progress on the doc yet..
Sam
Old 03-14-2012, 02:47 PM
Crazydan's Avatar
Crazydan
Crazydan is offline
Thanks Sam, looking forward to reading your doc.
Old 03-14-2012, 06:14 PM
fordman75's Avatar
fordman75
fordman75 is offline
I thought the Continentals were front wheel drive??
Old 03-14-2012, 06:22 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
yeh, missed that. mine is from a 1998 LSC rear wheel drive.
front wheel drive engines don't have the holes for rear drive transmission mounting. The block is different..
Sam
Old 03-15-2012, 12:12 PM
BACAGrizz's Avatar
BACAGrizz
BACAGrizz is offline
Front wheel drive 56 would be way cool. Is it a typo or do you have the front wheel drive trans?
Old 03-15-2012, 05:40 PM
Crazydan's Avatar
Crazydan
Crazydan is offline
The donor car is rear wheel drive
Old 03-15-2012, 05:48 PM
fordman75's Avatar
fordman75
Is it a Town car or a Continental? If it's rear wheel drive it should be a Town car or a Mark VIII. And is it a SOHC or DOHC 4.6L??
Old 03-15-2012, 08:21 PM
55 f350's Avatar
55 f350
55 f350 is offline
if it's a mark 8 it's a 4valve . also be aware that some lincoln models had a sneaky trick pulled on 'em especially front drivers , they got a 3.9 4 valve . it's the same as a 4.6 but diff stroke for sure . also front drivers have their own uique bellhousing bolt pattern that will not allow you to bolt it to a rear drive trans without a pricey adaptor .......... i looked at putting the 2 valve from my beater bird into my 53 for a bit . just a heads up , but if you go buy some of those neat little weld on frame brackets meant for a flathead with the waterpump having the front mounts in 'em .... well my bird uses a very simialar biscuit mount and frame mount .... see where i am going ????????????
Old 03-16-2012, 08:38 AM
Crazydan's Avatar
Crazydan
Crazydan is offline
Its a DOHC 4.6
Old 03-16-2012, 10:03 AM
BACAGrizz's Avatar
BACAGrizz
Where are you located?
Old 03-16-2012, 12:18 PM
Crazydan's Avatar
Crazydan
Crazydan is offline
I now live in Tulsa Ok
Old 03-16-2012, 12:46 PM
TomKo's Avatar
TomKo
TomKo is offline
Got a SOHC 4.6 with AODE sittin next to my frame right now. Paid $300 for it. Got it without the PCM but luckily was able to get the VIN which is key to finding the correct computer thru the Ford dealer. Also found out mine is out of a police intercepter. Found PCM on ebay and next will be ordering the detailed schematics for that car,also off ebay store. Probably the easiest way to do this is to order the Telorvic do it yourself harness but that is about $750. I'm hoping to get this thing mounted and running without that expense. I know some of these smart FTE guys have done it. It's my belief that some components or sensors can be eliminated and a PCM reflash? may be necessary. I plan to document this adventure in order to help others who may want to do this swap such as yourself. Right now I'm in the early stages of this process so not much help yet. Presently patching up my cab, then coat the bottom, set it back on the frame and start locating eng/trans.
Tom
Old 03-16-2012, 01:32 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
Tom
ford makes this reflash harder than others..
so you have to either buy an add on board
or one of the programmers, and have it programmed with a custom load.
On my 5.3l GM, it was $75 to send the ecu, programmed and postage back.
on the 4.6l its $150 (used) programmer (SCT X3 ), $100 programming service(cheap), and I haven't even wired up the engine yet.
DetailZone will reprogram the 4.6l ecu for $350. I don't know what happens if u need a change.
Sam
Old 03-16-2012, 01:55 PM
55 f350's Avatar
55 f350
55 f350 is offline
or do that swap to a carb and distributor that i mentioned so many moons ago from jailbait choppers and rods or something like that . i think they were wanting 1500-2000 and by the time you get done playing with wiring harnesses and ecu's and tuners , etc. you'll have that in it anyway .....................
Quick Reply: 4.6 liter install in 53-56 F100 anyone do it?
