So what did you do to your 6.0L today?
#8656
i think im gonna do that when i have the engine ripped out... might even replace the carpet....
#8657
I swapped tstats out and caused a leak. I clocked the housing clamp wrong. I'll pull it tomorrow and put the tstat in my old housing hust to make sure.
#8658
As I was cleaning I debated on new carpet, turns out my Carpet cleaner had a rip in hose. I eventually literally just poured 50/50 orange cleaner on it Scrubbed it with a stiff brush then used the shop vac to suck it all up. Faster and better then my carpet cleaner when it was working. Granted replacing it would have been a lot faster.
#8659
Also I'm not sure what it actually shuts off, Ill have to chase it down later on and see.
#8660
#8661
Josh is absolutely correct in harming the Injectors. The "safe" way to "kill" is via the FICM & I know yours is NOT currently set-up that way or u would NOT get it to start at all....Trust me, mine has a hardwired FICM kill switch
When u figure out what it is doing, let us know (curious) Just don't want to see u hurt your 6.0
#8662
#8663
Clayton,
I've gone this long with out using it, whats a couple of months.
If it is going to the fuel pump Ill just re-route it to kill the FCIM
#8664
#8668
(yesterday)
I finally installed an EGT sensor into the exhaust manifold and got it working with my sct x4. I also loaded up my "PerfEcon" tune from MPT. It gave me a lot of peace of mind, considering my EBP shows over 50psi at idle and 150psi at WOT on the sct tuner. I figured it wasn't reading correct or the cat was clogged. "normal" temps for stock exhaust setup told me its just reading wrong or the sensor could be bad. EGT didn't get over 900* on a 2 mile 6-7% grade unloaded at highway speed and settled to <400* after 2 minutes of idling, so i'm not as worried anymore.
on a side note, LOVING the PerfEcon tune from MPT. it smokes less than the street tune the SCT came with and has even more power, maybe more than the performance sct tune. I am still somewhat new to diesels and very new to the 6.0 and i gotta say, I am very impressed with the power these things make, even stock. coming from an 01 7.3, i wasn't expecting so much power.
now if I could just get my oil leak(s) figured out. the drip pan in the driveway is getting old fast.
#8669
ntm theres cigarette burns, soft drink stains and hardend gummy crap stuck in the carpet.. annoys me seeing it every time i get in the truck... couple of the seats have cig burns in them too..
#8670
Standpipes and dummy plugs
Finally got into this truck the other day. Its been many years since Ive had to do any major wrenching on a vehicle and was admittedly a little nervous about it. I dove into it before the flex head gearwrenches arrived and did major battle with the passenger side valve cover bolts. It is amazing how much easier those flexhead wrenches make the job. You've really got to get intimate with this engine to get the back bolts on these valvecovers LOL.
I had o rings for nipple cups and injectors, but after finding such an obvious failure on passenger side dummy plug and virtually no slop on nipple cups I decided to save them for another time. Thanks to FTE and youtube this job was a breeze.
Thank you, Kevin
Thank you, Kevin
