So what did you do to your 6.0L today?
Originally Posted by texastech_diesel
Shock or sway bar bushing rotted?
There is a frame side one. Mine keeps popping out on the driver's side. I attribute it to the puck lift that will be going away and lessened to only a 2.5" coil spring leveling kit. Maybe I already said this? Haha!
on
I did some major maintenance on my '05 yesterday:
-New front pads
-New Calipers
-New rotor
-Greased wheel bearings through abs
-Greased tie rods and ball joints
-Cleaned and greased both hubs
-Upgraded ESOF hoses with tighter fitting fuel hose.
Steering is now tighter and the truck now stops on a dime without shaking everywhere.
Next:
-New meats Cooper ST Maxx 305/70/16
-V/B code spring swap
-Rancho 9000 Shocks
-New front pads
-New Calipers
-New rotor
Next:
-Rancho 9000 Shocks
Is it inside the small steel sleeve bolted to the frame???
since after getting back from NC i didnt have the time to do anything else... i decided to pull the liner again.. when i first got the truck it wasnt bad under there.. seems things changed alot in the last couple years.. (been hoping to get to doing the bonded liner but havent had the funds... )
this was what i found today...
some places are worse than others...
little work with the angle grinder w/ wire knot wheel
whats weird is my last truck had a drop in liner for 20+ years and didnt look anywhere near like this one does.. only thing i can figure is the drop in liner in the last truck was anchored all around where this one is only anchored in the front..
shot of primer...
little white... doesnt bother me it doesnt match perfect.. like i said i eventually hope to do spray liner...
shot of primer...
I can get you a full 08+ for about $800 from a guy up here that has take offs.
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
