Making Progress 1956 F-100
More Progress!! I can feel it!
Making some small progress, but it counts!
Just picked up my backing plates and have some other goodies recently assembled:
Backing plates get their grooves welded and smoothed:
My Posies superslider springs W/3" drop:
Everthing is getting ready to be painted including my newly rebuilt rear end:
Hey Yamagrant - you're making me hungry! I love perogys!
NIIIICE! Yeah i kinda skipped the chassis cleanup and re-painting. It wasn't too bad but doesn't look nearly as nice as yours is turning out! You decided to keep the stocker rear axle? What gears are you running in it? Mine originally had 3.92s and had no idea what the mix-match 9" that was in my truck had. I think the 9" in my '56 is either 3.50, 3.25 or 3.00s. Still have to investigate that one.
More........
Hey Dano, I rebuilt the Dana 44 and put 3:73s in it. I'm told the 5.0/AOD shoukld be good with those gears. Kepp working onb yours!! Let see some photos!
Here's what I've prepped today - tomorrow brush POR 15 Semi Gloss Black, then Semi Gloss Black Topcote.
Parts reay to wash:
Washed:
Metal Prepped:
Dry:
Ready to paint tomorrow:
Almost made it, but "U" bolts too long
I made some progress this weekend. I thought I might have 'er sittting on the ground, but "U" bolts for the rear end too long.
I got my springs put up on Saturday:
Cleaned axles and install with backing plates Sun after Mothers' day breakfast (that I made!):
Slid 'er under and "bolted in":
"U" bolts too long, not threaded far enough - Back to the drawing board!!
Need to find and buy the right size - - Maybe she'll be on all four wheels next weekend!!
Happy Mothers' Day!! Joe
I ordered the same ubolts for my '53 after taking leaves out of the pack and ran into the same problem with the amount of thread. I tried getting ubolts from LMC, MidFifty, and Macs and none of them worked. I eventually went to a shop here in KC called KC Spring and for $50 they made some custom ubolts for me.
Going through the same thing
Just send my 2nd set back (from Speedway) because they were too long.
Spoke to Sacramento Spring and they will make me custom "U" bolts for $65.
Maybe in the next couple weeks I'll get myself over there!! Joe
