Sheet metal availability
Old 03-10-2012, 07:06 PM
62FE4x4's Avatar
62FE4x4
62FE4x4 is offline
Hey guys, I have found a 59 F250 factory 4x4 I am wanting to buy. Do any companies carry sheet metal parts for the 57-60 models? Thanks
Old 03-10-2012, 07:19 PM
ibuzzard's Avatar
ibuzzard
ibuzzard is offline
Panties NOT in a Twist
A few of the main-stream truck vendors sell repair patch panels, and Dennis carpenter reproduces the Styleside tailgate.I believe that's about it.No complete fenders, hoods, door skins that I'm aware of.
Old 03-11-2012, 06:21 PM
62FE4x4's Avatar
62FE4x4
62FE4x4 is offline
That is strange. I see these old pickups everywhere. You would think parts would be more readily available.
Old 03-11-2012, 06:23 PM
ibuzzard's Avatar
ibuzzard
ibuzzard is offline
Get used to it.And,get a small storage shed and fill it,is my advice.
Old 03-11-2012, 06:38 PM
62FE4x4's Avatar
62FE4x4
62FE4x4 is offline
Well I just bought the 59 F250 4x4, and I bought a rust free F100 so hopefully I will have everything I need. Don't the 61-66 models have a much greater selection on parts availability, or are they very limited as well?
Old 03-11-2012, 06:41 PM
ibuzzard's Avatar
ibuzzard
ibuzzard is offline
Yes.When you can buy parts at excellent prices,stock up your parts shelf.Some parts are difficult to find.You may not need them now,but you will some day.And like-as-not,when you need them most,they'll be hard to find.
Old 03-11-2012, 06:48 PM
62FE4x4's Avatar
62FE4x4
62FE4x4 is offline
I agree. Did Ford use the same flareside bed from 1958-1979? I have a 62 with 78 running gear that I want to swap the under bed fuel tank, bed, etc. to my other 62 with factory 62 running gear.
Old 03-11-2012, 07:07 PM
elgemcdlf's Avatar
elgemcdlf
elgemcdlf is offline
Not new but clean rust free used parts
http://classicfordtrucks.shutterfly.com/
Old 03-11-2012, 09:16 PM
spurredon's Avatar
spurredon
spurredon is offline
Wow, a junior user that knows the difference between a Flareside and a stepside! Give that man a Cupie Doll!
Old 03-11-2012, 10:08 PM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
Flaresides rule. And those that know the difference are true ford guys.....
Old 03-11-2012, 10:17 PM
62FE4x4's Avatar
62FE4x4
62FE4x4 is offline
Haha I may be a junior user, but that is only because I have forgotten passwords to two previous accounts. Haha I have had 7 flaresides, but I still don't know the answer to my question. Can anyone chime in with the differences over re years so I will know if the 78 fuel tank/bed setup will work with my 62 frame? Thanks guys
Old 03-11-2012, 10:24 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
Marmon-Herrington Man
VFN Fiberglass (VFN Fiberglass - All your fiberglass parts) has glass hoods. B & E Fiberglass, Inc, has full fenders. I don't have a web site but their email address is b-efiberglass@arvig.net. Stu
Old 03-11-2012, 10:46 PM
Les Knapp's Avatar
Les Knapp
Les Knapp is offline
Les
I have both doors, both finders, hood, and lower part of the grill, both headlight brackets, and tail gate for 57-60 F 100.
Also I have both front finders, left door for a 61-66 F 100-250, grill/top part for the hood latch, for 61 F 100-250. I've got other Ford parts too.
Call me at 541.660.2344
Old 03-11-2012, 11:22 PM
elgemcdlf's Avatar
elgemcdlf
They are not the same. The '73-'79 truck widened the rails just behind the cab. It is also 2" longer than a '67-'72 bed. The '67-'72 trucks are 2" longer in wheelbase than '61-'66 trucks but I do not know where. It may be in the cab area so it might be the same bed as yours & the '67-72. Not a complete answer but hopefully it helps a bit.
Old 03-12-2012, 12:51 AM
62FE4x4's Avatar
62FE4x4
62FE4x4 is offline
That definitely helps. Now we know the 78 bed will bolt into the 62 frame without any mounting issues. What about the 78 fuel tank behind secured to the 62 frame?? I believe the 62 frame is narrower than the 78? Will the fuel tank (behind rear axle) still work?
Quick Reply: Sheet metal availability
