Auxiliary Power Point Part needed
I need to find a place to order the Auxiliary Power Port that is in the dash. The local dealer can get me the actual cigarrette lighter part 19N236, but I need the plastic garage door style surround. I removed the dash and removed the broken part which appears to me to attach with 3 screws. My truck was used when I got it and it looks like someone just pushed it in. The dealer told me they can only order the whole dash which is a bit ridiculous at $600+. Does anyone know where I can get the assembly?
I see part #s
T5394 & F81B-25046A02-AIW (assembly) - part that is broken
T5393 (Sliding Cover)
I was going to glue it back together but parts of the plastic that broke are missing.
Thanks!
Tim
I see part #s
Thanks!
Tim
I would suggest a junk yard closest to your home, quick and cheap!
Outside of that you could try calling Tousley Ford Parts Depot
at 800-328-9552 they have been a big help to me before and will ship anywhere.
I hope you find it!
I hope you find it!
I think I read that it is only serviced as part of the whole dash section. Here, I found it ........"Powerpoint socket and mounting ring, in dash (NOTE: if the sliding door which covers the powerpoint is damaged, the complete 044D70 Cluster Finish Panel will need to be ordered - this door is NOT serviceable), 2000/ 2004 ; Ford 250 Series"
Sorry...Junk yard or maybe here... Ford Part List if the $$$ isn't too much depending on your configuration?
tjw05
01-14-2011 12:26 PM
42thefloor
09-09-2005 10:38 AM
