78/79 RestoMod
#466
Reviews are excellent and they have a 5 year warranty. Not sure about the serviceability of the individual gauges but sending units are cheap and easy to take care of and usually the cause.
#469
#470
Also with the holidays coming up I decided to divert funds to take a trip to visit family for Christmas. Hopefully Santa will bring the gauges for Christmas lol.
#471
#475
Spent some time this weekend and got the engine bay cleaned up and ran the wire harnesses ran the way I wanted to.
Also worked on the engine, I got most of the accessories on and then realized the power steering pump is misaligned. Turns out the new water pump mounting points for the power steering pump are too long, so I will need to grind them down, ugh.
A few things to do before the engine can go in, I need to seal up all the unused holes in the firewall and get the heat shield installed. Another thing I want to do is replace the reverse light switch, it works but the connector is loose.
#478
#479
This engine is tight!
I pulled out the drill to prime it today, the 18 volt barely had enough power to run the pump so I pulled out the 1/2" plug in drill to get the job done.
I connected my multimeter to the sending unit out of curiosity, it held pressure under 5 ohms for over 10 minutes after I stopped running the drill, gotta love that!
