38R + AC codes + AIS intake = not enough AIR
I've had a 6637 filter on the dually for almost 250k miles now - but after getting the 38R it has just been too noisy for my liking. Actually, I will describe the good 'ole 38R as downright punishing while towing with the 6637 filter in front of it. All I can say is those of you who WANT a louder turbo must not tow heavy for 12-14hrs at a time - because the added fatigue from this noise is very noticeable...
So, since the AIS will flow nowhere near enough air for what I have planned for the Excursion's engine build - I figured I'd throw it on the F350 and try to quiet down the damned oboxious 38R. IT WORKED!!! I had actually decided I would keep the 38R after my first couple of drives. Then, I realized I could max out the filter minder at will... No big deal I thought, it still easily makes 30psi of boost (FAST too!! ) and EGT's just are not an issue with the tuning I have now - so no big deal. Then I realized I added 1.5gals of oil between oil changes (usually I don't add ANY). (sucking oil out of CCV???)
I cut a 2" dia hole in the side of the box for a filter sleeve and it had zero effect - still max out the filter minder after a WOT event... I guess the AIS will be for sale, prepped for a 'fender sleeve' mod.
Meanwhile, I guess I need a recommendation for a 'closed-box' filter that will flow enough air!!!
Jason. I had the same issue with the 38r and 6637 but I like the whistle from the turbo. Didn't like the minder light so I went to the AFE big boost filter,I can still set the minder light @wot..the AFE is rated at 850 cfm..I believe Jody at DP is using a closed filter that rated at 1100 cfm,I am planing on getting that info on which one that is and trying it..
I experienced the same thing when I put my AiS on, five years ago. It turned out the filter-minder was the problem. I put the old filter-minder from the stock air box and it never pegged again. The AIS box was actually flowing plenty of air, the filter-minder that came with the AIS was faulty.
Chet
What about a stock 6.0 intake?
I thought about the oil and there could be many reasons he used that oil unrelated to the air box not flowing the air. I have never heard of an AIS box not flowing enough air.
What is the basis of your "...the recommendation is do not use an AIS. Too restrictive." comment? Just wondering where this comes from.
I was ready to get one untill this came up earlier today.
For me, more research necessary.
Stewart
