Studebaker rims for F5
Well, no, you don't want those. First of all, they too are widow makers. That raised band like area along the mid-line of the rim is the joint. Second, they are hub piloted while Fords of our era had stud piloted wheels. Those wheels are no doubt on an early '50s Studebaker 2R15 or 16. Studebakers of the early '50s, GMCs of the 1940s, and REOs of the '40s all used these wheels. You can see that there is a washer behind the lug nut which is the tip off to a hub piloted mounting. Below is a diagram that lets you see it. Stu
If you don't have need for the truck, you might drop in over at the Studebaker Truck Talk forum (STT) and make it available to those guys. Tell them I sent you. Stu
Exactly. I catch myself looking at the wheels and lug pattern of just about every big truck I see.
Brian - The brake drums on your F-4 are the very same as used on the F-5s and F-6s. The 19.5s with 5 lug x 8" bolt pattern should fit all the F-4/5/6 trucks. There's gotta be something that caused them to not clear your drums. Are you sure you didn't have some obstruction preventing the wheel clearing your drum? We've got probably dozens of members that have successfully used them without problems. Stu
Okay, that explains it. A 17" Budd will fit a front drum, but not a rear drum. Which has been something that's puzzled me because the center disk of a 17" is exactly the same diameter and shape as a 19.5" center disk. Matter of fact, American Wheel Specialist uses donor 17" centers to make their custom 19.5s. The center fits perfectly into the rim and is welded to the rim's drop center. The 19.5" drop center rim moves the tire mounting surface outward just enough to clear, and we are thankful for it. Stu
FordsOnlyGarage
07-04-2017 11:02 AM
maytea
06-01-2017 09:55 PM
Azfordman60
12-30-2009 06:17 PM
