Ever seen a 3bbl carb???
Old 03-04-2012, 09:47 PM
1983F1503004x4's Avatar
1983F1503004x4
1983F1503004x4 is offline
Originally Posted by kedwinh
I know they used to make 3 barrel carbs back in the late 60's, think it was AFB. But those were monsters, 2 good size primaries and 1 LARGE secondary. That's the only 3 barrel I've ever heard of but then again I don't mess with foreign cars much.
The Carter AFB and AVS are 4bbl square bore carburetors.
http://s3.racingjunk.com/ui/2/73/250...50CFM-3BBL.jpg
That's a holley 950 CFM 3bbl.
They came in 1050 CFM versions too.
http://forums.vwvortex.com/showthrea...805&viewfull=1
There's an inline-3bbl carb! Huh... wonder how that'd work on the 300?
Old 03-04-2012, 09:54 PM
1983F1503004x4
Looks like I finally found an explanation for the mini-venturi.
Turns out, it's called the auxiliary venturi, and is a miniature carburetor within the carburetor.
The fuel is drawn through the auxiliary venturi into the pre-combustion chamber on the 1.8 L inline 4. The primary and secondary serve normal motor function.
HONDA KEIHIN CARBURETOR REPAIR
It'd probably take eight of those things to run the 460.
According to what I saw, the 1.8L was able to pass emissions testing without being factory equipped with catalytic converters! The auxiliary venturi ignited a fuel mixture in the pre-combustion chamber to begin the burning process, while the main mixture is drawn through the primaries and secondaries. The auxiliary venturi and the pre-combustion chamber lengthen the burn time of the fuel mixtures to ensure a more complete burn and as a result, the nitrous oxides and the unburnt fuel is burnt as well as an extremely efficient oxidation process for CO.
Now it makes me wonder why we weren't doing this in the US?
Old 03-04-2012, 10:10 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
I remember working on those CVCC Accords back in the very early eighties.
Old 03-04-2012, 10:26 PM
1983F1503004x4
So I guess my question is...
What's the point of a 3bbl?
On the Honda, the 3rd venturi was used for emissions reasons.
On the Holley, it was used for performance reasons.
So why did 3 barrels go out of style?
Old 03-04-2012, 11:30 PM
kedwinh's Avatar
kedwinh
kedwinh is offline
VWVortex.com - SOOO, there was a rabbit and a poodle.....a killer poodle, with a 2.5 inside.
Yep that's the one I was thinking about probably. Just couldn't remember who made it.
Old 03-05-2012, 11:04 AM
85lebaront2's Avatar
85lebaront2
85lebaront2 is offline
Old School Hot Rodder
The Honda CVCC engine used the third barrel to feed a prechamber with a nice easily ignited mixture, the flame from this would ignite the lean mixture in the main combustion chamber. These engines were prone to valve stem seal issues, causing the very tiny prechamber inlet valve to carbon up. When this happened the engine wouldn't run very well except at full throttle. The first one of these I saw, the dealer had sent it to my shop. The original Prelude used a sidedraft 3 carb assembly that Honda serviced as one.
The Holley 3 barrel was an upgrade from their 850cfm 4 barrel, it went out of favor when the 4500 Dominator came out.
I have seen a number of other 3 barrel carbs, Solex built several, one for Porsche 911a, two different styles for SAAB, the 850 Monte Carlo used a downdraft and the Sonnet used a side draft. Weber built a 3 barrel for the Porsche 911s, a 48IDA3P, and I think I have seen similar ones used as a foursome on some Italian V12s.
uncle jessie
02-23-2005 11:20 PM
jzjames
13
01-18-2005 04:10 AM
teederj2002
11-12-2004 10:54 PM
hdwilly
Offroad & 4x4
03-12-2002 06:09 PM
Quick Reply: Ever seen a 3bbl carb???
