You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Can't find a replacement but see where Carpenter sells one for a 61-67 Falcon. C0DZ-2760-B = 1960/65 Falcon (and etc, see below) / 1966/70 Falcon uses a foot operated parking brake, handle (C5AZ-2760-A) is totally different.
anyone tried to see if a Falcon parking brake handle fits the Econoline?
Applications: 1961/64 Econoline / No Ford Dealer or obsolete parts vendor has any.
Will the Falcon handle fit? I dunno, have no experience with such. I do know the Falcon handle will fit 1961/66 F100/350's in place of C1TZ-2760-A (not repro'd), but...
It will only fit one way: UPSIDE DOWN!
C0DZ-2760-B .. Parking Brake Handle / Reproduced / Applications: 1960/65 Falcon/Comet / 1962/65 Fairlane / 1965/66 Mustang.
---------------------------------------------------------------------------------------------------------------------------- EDIT: There is another solution, replace the entire park brake control / There are 10 available NOS
C3UZ-2780-A (replaced C2UZ-2780-A) .. Park Brake Control ~ 1961/64 Econoline / Obsolete
C2UZ-2780-A =
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
-------------------------------------------------------- C3UZ-2780-A =
CARPENTER NOS OBSOLETE PARTS in Concord NC has 3 = 800-476-9653.
GREEN SALES CO. has 5.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
IT WORKED.......
bought a parking brake handle from Dennis Carpenter ( Scott Drake part) for a 64-66 Falcon....part number CODZ-2760-B
to remove the old handle it had a press in dowel so I used my handy little zip wheel to cut off the old handle( had to cut thru handles metal innner case) cause could not pull out dowel...
put new handle on and used the screw in plug...
yes handle is opposite of stock but works fine and is not in the way.......
I could have drilled a new hole to make in line up right for stock position but it works fine...
I had a home made bit of pipe welded into a tee held with a nail when i got my van, was able to use the handle end from a 78 toyota pu. it too is off center.
svj
