Belt length/part # for smog pulley bypass
I dug up several old threads and posted in one of them to try and get a definitive answer on the length of belt needed to bypass the air pump pulley on a 1992 5.0.
I recently ditched the air crossover tubes and all associated piping/ vac junk and I want to now run a shorter belt. My pulley configuration has the tensioner up top between the alt and a/c. So I know I can keep factory routing.
What length should I go with and any suggestions on a brand? I'm up in the great white north, so I don't know if my options are limited. I'm running a prestone right now, which has been awesome.
Thanks guys!
Thanks guys!
Found a thread on a mustang forum that says an 84.5" belt would do it on a 5.0. Does that sound right?
Check out the pic in the second post...
http://www.allfordmustangs.com/forum...belt-size.html
Well mustanGs use a little different accessories on the front. But give it a try.
If you have your old belt just cut it and wrap it around and mark where it overlaps.
That's all I usually do.
Then get a belt and try it. Then if it's not enough tension on it get a little shorter.
I can always try the 84.5"... or does that sound too short?
I tried measuring with a string by bypassing the smog pump, but I really had some trouble haha. Its raining out, I cut my hand on the shroud.... so I really botched it. Got around 88"
No worries buddy. I know how you feel. By the part number, I'm assuming belt length is 91.5" that you have? That's right around stock length, no?
