Good or bad?
Good or bad?
Just started into my cab today on my 56 F100, needs a lot of work but thought i would get suggestions on the condition of the cab and how i should go about fixing it. This is my first build and am learning alot. I think i will go to harbor freight and buy one of their $100 welders, any suggestions? The 408W is complete and readay to go, I also have prepped the new frame, ill add those pics shortly. Thanks!!
Motor and new frame
Still trying to figure out what vehicle my front clip came out of. I thought it was a 72-76 torino, the only reason i came up with that is from all the pictures ive looked at online of other front ends, i could be wrong but the motor mounts i ordered for it fit like they are supposed to so im pretty stoked about that. The only thing i have left to do is rebuild the front suspension, the only thing i came up with doing is tearing all one side down and sending all the bushings and ball joints in to see if they can match them up, thats the only way i can think to make sure i get the right stuff. Any one know any good sites for suspension rebuild kits? Thanks.
I agree, from what I see, that cab is in excellent shape. I'm not even sure what you'll need a welder for.
But seriously, before I spent $100 at harbor freight on a cheap welding machine, I'd search my local ads for a good, used name brand unit. One that is less likely to fail, and if you do need parts or service, it'll be readily available. Even at your local welding supply store, you can often find really good deals on demo machines or ones that were very lightly used for training, etc., at significant discounts. I've got a small Lincoln SP135 I picked up on a deal like that for about 40% off the regular price, and it had less than a half spool of wire run through it. That machine will very likely outlast my lifetime. I've yet to finish that spool.
I agree. Either that or go your local Napa or other parts house and you can get just about every piece you need. I'd be hesitant about ordering a kit on-line until you know exactly what you have. I have seen enough big-body fords to tell just from looking at them but know that latter 70s Thunderbirds, LTDs, Cougars, Torinos, Montegos, etc.. had subframes. Somtimes taking in the brake parts and matching those up can be the tell-tale sign. What is the bolt pattern on the wheels?
As for your welder... be sure to get one that is gas shielded (uses a bottle with gas). Flux core is garbage, especially if you plan to use it on sheetmetal. I'd be cautious of China Freight's welder, not sure what you're really gettin and a welder is a piece of equipment that needs a bit of precision to operate correctly. Get .025 and .030 mig wire and the applicable tips for the gun and should be set to go.
Ha Ha... posted at the same time as Nighthawk and Merc!
I'll second what Merc says and try combing the ads (even craigslist) for a good used name-brand welder. You wont be sorry.
And by the way.... I am jelous... that IS a great looking cab!!!
Cab
Thanks for all the comments, I thought it was in pretty good shape, the cab corners definately need replaced, i already have both front replacement corners, i also have a complete cab mount kit from mid fifty with the adjustable cab arms. i included a close up pic of the worst spot on the floor. That is first on my list to fix. Ill definately check out craigs list and some local websites for a welder, very good idea. I didnt even think about just taking the old bushings and such to napa and just having them match them up, ill definaely do that as well. I loaded the truck up about an hour ago on my car hauler, im going to try to get some things done while im at work tomorrow! Thanks for all the advice, any advice on how to fix this spot is much appreciated!
welder
would this be a good deal? whats better mig, tig, arc?? im new to the welding scene, anxious to try it! ive done it once but it was in school. Thanks.
lincoln pro mig welder 135, with gauges.used about 5 min.
Make sure the welder has the sheilding gas hook up. I started with the cheap Lincoln 110v flux-core welder, big mistake. After welding in my floors, it worked but not pretty, I bought the Lincoln 180 with gas, I now look for things to weld. It also allows you to use thinner wire which means less grinding. The best tool I've bought for my build.
You've got a great looking truck to start with, enjoy!
Brian
Brian
Tig is the best for sheet metal work. However it's a bit more difficult to learn and quite a bit more expensive to get into. Mig is the best all around and that Lincoln 135 should do the trick. Like Brian said, make sure it has hookups for gas and you'll want to use .025 wire for sheet metal work.
Lincoln makes a good welder, and that one can be used with either shielding gas or flux core wire. I haven't used one of theirs (I have a Hobart Handler 175). The lincoln is probably 110v, but you should check to make sure, especially if you don't have 220 in your shop/garage.
Home Depot carries Lincoln welders, so you could check there to see what they go for new.
At 135 amps, it would be more than enough for sheet metal to 3/16" or so. Other than chassis fab, it would probably do just about anything you would need.
