95 f350 460 automatic gear selector question?
Old 03-17-2014, 02:04 PM
460mayhem's Avatar
460mayhem
460mayhem is offline
Question 95 f350 460 automatic gear selector question?
I parked my car overnight and the next morning I jumped into my truck and turned my key but my truck would not turn over. All my power was working in the truck so I knew it was not my battery and my starter is new. So I went under my truck and moved my gear selector, it was a little loose. That fixed my problem I guess my truck was not in park so did not crank. But now my automatic shifter is working properly again. Here are some pictures of my selector. My question Is that my gear selector looks a little too close to the edge of the rod or is this its normal position.
Old 03-17-2014, 11:34 PM
94GreenTruck's Avatar
94GreenTruck
94GreenTruck is offline
I had this exact problem after i had to put a whole new shift linkage in my truck. The easiest solution is follow the linkage up underneath your dash by the pedals and youll see a place where the linkage comes to a plate with two brass hex bolts on
it. Tighten those as snug as you can. That should make gesr selecting a little tough but it will loosen with time.
Old 03-18-2014, 01:10 AM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
The rod being there shouldn't cause you any trouble, there is a plastic clip a little down the line where you can tighten up the linkage if you want to, but anyway, I would actually consider replacing the linkage if it's too old. A broken linkage can actually make you break the shifter tube trying to get the truck in a gear (I speak from experience), and it's quite a bit more involved and twice as expensive.
Old 03-18-2014, 04:45 PM
460mayhem's Avatar
460mayhem
Thanks for the fast response everyone ! I'm a new member. I will take a look at the plastic clip and the hex nuts, if the mechanism needs replacement I will get er done. Thanks
Old 03-19-2014, 02:13 PM
jekyll_hyde's Avatar
jekyll_hyde
jekyll_hyde is offline
Try and post updates as far as what you do I am having similar issues with my 94 F350 460. But there is still snow and ice on the ground where I am so a little less likely to be doing anything soon..
Old 03-19-2014, 03:02 PM
danr1's Avatar
danr1
danr1 is offline
Wires look cut then spliced together, might wanna look into that. Can't make out wire colors but kinda appears as someone might have bypassed Neutral/Park interlock function right there at the MLPS.
Shifter cable end is in its normal position on the post, that pin has a grove in it the grommet in the gable loop locks into.
Model year is known for shift cable bracket coming loose up at steering column end, couple of torx bolts retain it to the end of the shift tube, worth a minute if for nothing else verify they are tight.
Looks like a connector unplugged too (just behind the two wires twisted together in the image..... those two wires are twisted together right?) but hard to say for sure picture tad unclear, didn't mention much about truck though and connector size/shape pin count doesn't ring a bell at the moment that location either, possible its something else and not a connector too!
Old 03-19-2014, 03:21 PM
subford's Avatar
subford
subford is offline
X2
Old 03-19-2014, 03:26 PM
460mayhem's Avatar
460mayhem
Yes you are correct the wires have been twisted together by the previous owner to bypass the neutral park. I will take a look at it today, it seems like something can be loose. I don't like spliced wired I will look into replacing that sensor / harness.
Old 03-19-2014, 03:28 PM
460mayhem's Avatar
460mayhem
Thank you for the picture reference !
M.Rad.
02-18-2014 09:09 PM
camodown
22
01-12-2014 03:46 PM
fordguy622
1999 to 2016 Super Duty
03-14-2012 07:40 AM
smallello
53
02-17-2012 06:56 PM
pdavila
1978 - 1996 Big Bronco
08-28-2004 11:38 AM
Quick Reply: 95 f350 460 automatic gear selector question?
