Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
Bronco Custom 1979 400 rebuild
Old 11-11-2012, 06:39 PM
abrojal's Avatar
abrojal
abrojal is offline
Hi Guys, Im from Argentina and this was my engine rebuild project
Bronco 400 with TMI pistons, the first one here.
this is my 79 bronco custom, it has a 351M engine with C6 auto trans.
I got 400 crank and pistons, and I´ll swap the C6 for a ZF5 manual trans.
I turned off the engine in may 2010...
Old 11-11-2012, 06:41 PM
abrojal's Avatar
abrojal
abrojal is offline
5/19/2010
removing the engine
C6 broken part...
bronco coming home without engine
Old 11-11-2012, 06:46 PM
abrojal's Avatar
abrojal
abrojal is offline
First I got an used Edelbrock Performer 400 intake, but I sold it and finally I got this brand new weiand action plus +
Old 11-11-2012, 06:47 PM
abrojal's Avatar
abrojal
abrojal is offline
oil pan and the carburetor
Barry Grant Demon 625CFM
Old 11-11-2012, 06:48 PM
abrojal's Avatar
abrojal
abrojal is offline
Tmeyer sent me these
400 Hypereutectic Piston 9,3:1
Premium Rings
Kit Gasket Set
Expansion Plugs, Brass
Oil Pump
SBF Lifters
"335" series-Gear Drive-Quiet
Ultra Slick Engine Assy. Lube
Plastigage
ZDDP oil additive- 4oz. bottle
Cam Bearing Set- Grooved
Valve Spring, Retainer and Locks kit
HARMONIC BALANCER
Engine Bolt Kit- 351M/400
400 Crankshaft Kit
rod and Main bearings
351M/400 Push Rods
BBF Roller Rocker Arms
1.650" Exhaust Valve
2.040" Intake Valve
351M/400-Water Pump
Old 11-11-2012, 06:49 PM
abrojal's Avatar
abrojal
abrojal is offline
Old 11-11-2012, 06:50 PM
abrojal's Avatar
abrojal
abrojal is offline
Old 11-12-2012, 12:56 PM
abrojal's Avatar
abrojal
abrojal is offline
abrojal's Avatar
abrojal
abrojal is offline
Old 11-12-2012, 12:58 PM
abrojal's Avatar
abrojal
abrojal is offline
Old 11-12-2012, 12:59 PM
abrojal's Avatar
abrojal
abrojal is offline
you can see a friend working, also he is developing the new Radius Arm Drop Brackets for my custom.
Old 11-12-2012, 01:00 PM
abrojal's Avatar
abrojal
abrojal is offline
abrojal's Avatar
abrojal
abrojal is offline
the paint is almost done
Old 11-12-2012, 01:02 PM
abrojal's Avatar
abrojal
abrojal is offline
Old 11-13-2012, 04:41 PM
abrojal's Avatar
abrojal
abrojal is offline
Quick Reply: Bronco Custom 1979 400 rebuild
