Steering Box
Duralast/Steering Gear (Power Steering) $274 + core.
Is it this one a Autozone?
Duralast/Steering Gear (Power Steering) (7817) | AutoZone.com
I also have moog ball joint and moog tie rod life warranty.
I went with MOOG on the ball joints and have not had any problems so far (I keep them greased religiously). Pro Comp on the suspension system, can't complain yet on the performance. I went cheapo (autozone) on the steering box due to limited funds at the time. It came with a lifetime warranty....I have swapped it out (freebie) already.
Constant inspections and preventative maintenance on your truck will trump everything! Don't wait until the "uhoh" moment.
Good Luck.
[quote=K80;11480860]I have no mods on my '05. As I mention, I use this truck as I would an SUV, nice and easy and for long distance trips. I use my '08 Liberty for local trips......Got my truck back from the dealer yerterday; they put in a re-built box and did an alignment. After I got it home I looked and found the grease boot cut at the Pitman arm and also the steering wheel offset to the right (about three inches) as I am driving straight. It is going back Tuesday. The service manager says a little cut in the booth is not a problem as there is enough grease packed to prevent road dirt from doing damage. I would not expect this from a dealship since this is all paid for by my Ford extended warranty. This is my second extended warranty ($5,800 spent) and little by little I am getting my money back as this is by no means my first extended warranty work.....on the invoice they list an 388898s seal, I wonder if this is the grease boot that should have been replaced and not used. Anyway, thanks for all your replies and input concerning this job. Mike
As a follow up to my thread above: Brought my '05 back to the Dealer today to deal with the off-center steering wheel and ripped grease boot on the drag link. They replaced the drag link and re-aligned the front end....all is good now; steering wheel is centered. Thank you all for the advice so mentioned in your responces. Mike
#28
Redhead replaces the bushings with bearings when they reman these boxes. Get a redhead steering gear.
I installed a Redhead gear; ball joints (XRF); axle seals; tie rod ends; drag link this past August. Drives like a champ now. No more correcting all the time as I'm going down the road.
#29
I am organizing a redhead steering box group buy in the excursion forums. Here is a link:
https://www.ford-trucks.com/forums/1...g-box-buy.html
We currently have enough people for a $50 discount off the price of a box, if your interested read the thread it has lots of useful information and is a very highly recommended modification.
#30
For the ones that want a Redhead gear box you might want to have a look at this post
they are doing a group buy on then and there will be some type of discount.
I for one will be jumping on this.
Sean
Sean
