sudden excessive back pressure
Hey Paul,
Looks like the missing piece was pounded to powder into the top of the piston. Found a very few pieces of really fine grit in the oil but nothing else. Will let the head shop find out if there are any pieces stuck in the valves for sure, but it doesn't look like it.
Pulled the driver side this morning and all looks well there. No obvious damage. LOL I did figure out that this motor has been rebuilt once, just couldn't find out what the mileage was when it was done.
Will let you all know more as I discover it
Judi
Judi
Judi, Judi, Judi...(Cary Grant)
You have the intake, heads, exhaust and many, many other parts off a 98,000 mile motor.
If I was looking at a broken piston, at that point, come on,... I would get a remanf. short block and start over - especially if I lived in the motorhome as you indicate you do.
You are certainly going to pull that piston and check it out, now you have the pan off. A new head job will put additional strain on the bottom end, so the odds are getting too long for any reasonable level of reliability, if you ask me.
The odds are getting too long for any reasonable level of reliability, if you ask me.
Hey Paul,
Judi
Judi
If need be I can get you a smokin' deal on a reman 460 here in PHX area as good friends with owner of a engine reman place. For probably less than you can patch that engine. shoot me a PM.
Hey Paul,
Judi
Judi
I think his pricing is too cheap for what you really get. Kind of like a factory he just has it down pat on how to do it. I can be a go between if you want.
If it were me I would request zero deck or no more than .010 in the hole and balancing.
Five Star Engine Exchange
899.00 for a 390 long block with a 1yr unlimited mileage warranty is pretty hard to beat. Difficult to buy the parts and a bit of machine work for that price. He buys so much parts he passes the savings to the customer. Request about any thing you want in brand names.
Be aware that if a reman 460 short or long block is ordered, that Ford changed the 460 mid-year 1979.
1971/78, some 1979's: The block casting number is D1VE-6059-AB = Does not use a weighted spacer.
Some 1979's, 1980/97: The block casting number is D9TE-6059-AB = Uses a weighted spacer.
The harmonic balancer and flexplate used with the D9TE block are not the same as used with the D1VE block.
desperado_18_2000
06-12-2010 11:51 PM
-jeremy
02-02-2006 11:11 AM
DuraSparkMike
04-25-2005 05:39 PM
Boss_358
02-04-2004 09:08 AM
