Yellow Sludge in Oil
I noticed today that I had a milky yellow sludge in my oil on the '60. I've seen this type of sludge before but never this amount of it. I was told at one time that it's a result of water in the oil so I'm a little afraid that I might have something bad going on in the ol' Y block. I have had the truck for about a month but today was the first day this was present.
I changed the oil, but there was a lot of this left in the filler tube and on the dipstick.
Anyone know what it is?
Do you run a PCV setup, or just the stock draft tube? Since this appears to be a new thing for your engine, is it possible you've just not gotten it fully warmed up since the weather turned colder? Condensation can cause this if you don't ever get the engine up to 180+ for an extended period to burn off the water.
I'm with ALBUQ F-1; mainly because you bring it up this time of the year. it's the same reason sometimes water drips out the tailpipes when its very cold out. after running, while cooling down it draws moisture out of the air.
i'd check all the stuff mensioned, PVC, crankcase vent/breather.
my 84 dodge 318 gets it in the dipstick tube every winter (and goes away every spring)....but that motor has 200,000 + miles.
Antifreeze was my first thought but the temp gauge looks good so I can't imagine it is mixing or wouldn't it overheat?
I had completely forgotten to mention that it does have a PCV valve. I noticed this sludge in the oil breather cap first- actually dripping out of it. I'll take a look at the PCV but it may just be the cold weather...I'm sure that has something to do with it as it's been fine up until yesterday.
Also, I drove it for a few hours yesterday, and probably 50 miles or so, so it should have gotten hot enough. I had wondered if the previous owner put in some low temp thermostat or something.
Thanks.
Thanks.
Well, I drove about 20 more miles today, parked the truck, checked the oil dipstick and the tube and the sludgy stuff is still there. The odd thing is that the radiator cap was not hot. Every other radiator cap I've had would scald you if you touch it, but I could hold my hand on this one as long as I'd like. It was warm, but not hot. I wonder if there's a 160 degree thermostat in there because of the warmer climate in Georgia, where the truck used to reside.
Update: I just looked at the oil that came out- put it into a see through jug and there are NO traces of green or water in it. Now that I think about it, the oil wasn't even remotely hot when I changed it yesterday, yet the temp gauge showed in the middle.
I'll put in a 180 thermostat...next I'll be asking about why the gauge shows I'm overheating!
