1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
GEM module
Old 04-24-2003, 03:44 PM
blow's Avatar
blow
blow is offline
Angry GEM module
Recently bought a 2000 EB Expedition, a couple weeks ago the defroster started coming on in the middle of the night and other goofy electrical problems. The other day the battery was dead, I got it jump started and noticed a noise like relays chattering away under the dash on the drivers side. Brought it back to the dealer and he said that the GEM module was corroded and needed to be replaced. Is this a common occurence ? Any body else had this happen to them? Thanks.
Old 04-24-2003, 08:15 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
GEM module
Hi blow,
If you do a search on here you'll find that that is quite a common problem. It is usually caused by a leaky windshield. Dont replace the GEM until the windsheild is resealed or you'll probably end up doing it again
Old 07-14-2003, 08:22 AM
mountainman101's Avatar
mountainman101
mountainman101 is offline
GEM module
where is that module i had my ac fan on all night
Old 07-14-2003, 09:11 AM
Racerguy's Avatar
Racerguy
Racerguy is offline
GEM module
The GEM is bolted to the back of the fuse box.
Sometimes though the fuse box gets water in it and causes the same problems too.
Old 07-14-2003, 02:17 PM
00Expo&73Bronco's Avatar
00Expo&73Bronco
00Expo&73Bronco is offline
GEM module
Been there done that too with my 2000. Repair place insisted that their was not a leak and everything was dry up there behind the dash.
Old 05-04-2006, 09:09 PM
stardust's Avatar
stardust
stardust is offline
GEM module/fuse box
I had this same problem, but my wipers wouldn't work at times while it was raining. I did some research & found that a lot of expedition owners have this problem.
Old 05-05-2006, 05:46 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
... Welcome to Ford Truck Enthusiasts!
This happens to be an old thread, however stick around and someone will be by to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 05-05-2006, 09:31 AM
mountainman101
gem module dont always replace
my problem was withy a short in driver door ajar switch had short cut wire to switch it stoped put new switch months later without switch when u close door exit truck with keys in pocket windows switch works left dog in truck went to bathroom in gas station dog opened window exited truck chased him for a half hour was a untrained puppy ford dealer wanted to replace my regular mecanic found the code
Old 05-05-2006, 03:16 PM
pitrow's Avatar
pitrow
pitrow is offline
Geez, you might wanna try using punctuation next time. It makes it so much easier for your readers to try and figure out wtf you're trying to say.
Old 05-07-2006, 08:23 AM
Charlie Santi's Avatar
Charlie Santi
Charlie Santi is offline
I had to have the GEM and fuse panel replaced on my '98 not long after I bought it. The truck had some weird electric problems and the repair took care of they. The dealer did it a no charge, then sent parts to Ford. Never found out what was wrong.
Charlie
Old 02-02-2008, 02:37 PM
CACHO23's Avatar
CACHO23
CACHO23 is offline
HELLO,
I want to see pictures about de GEM, for the history problems mentioned by other fiends Im thinking that i need to get one.. please somebody show me the electrial part. thanks
Old 02-02-2008, 02:43 PM
CACHO23's Avatar
CACHO23
CACHO23 is offline
my truck is a 1997 4x4, and the interior lamps not turn off always its on and the door ajar lamp in the dash goes on too.
Old 02-05-2008, 08:33 AM
leunhenr's Avatar
leunhenr
leunhenr is offline
I have a Ford F-150 and I had a leaky windshield a while back, and the dealer said I needed to have the GEM module replaced. I've already taken the old GEM out to look at it and put it back in, so I know how to replace it. But if I buy a new GEM module, does it need to be programmed by the Ford dealer before it can be used? I would hate to take the truck to Ford for them to replace the GEM because they charge an arm and a leg for it, while it's so easy if I just replaced it myself.
Old 02-05-2008, 09:09 AM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
You guys might want to start new threads about your problems rather than posting in this old one.
Old 02-05-2008, 06:45 PM
madsonp's Avatar
madsonp
madsonp is offline
Spray some WD 40 in your door latches, this should fix your problem. this is a common occurance with these vehicles.
Quick Reply: GEM module
