Heated Seat upgrade
Heated Seat upgrade
I have an '01 F250 CC, Platinum Edition, VIN 1FTNW21F11EC53447,apparently even this didn't come with heated seats, power yes, heated no. This is my first vehicle with leather seats, now I know why they make heaters for them!
Thinking I could just buy the needed items, like the seat wire harness, the switch, the heater elements, the heater control module, etc...... plug and play, right? wrong.... The main issue is the connection between the harness and the heater control module. The harness is a 12 pin connector and the module is a 10 pin connector I know/understand the connection between the truck and the wire harness doesn't match (4pin to 8pin) but in the scheme of things, no big deal.
The wire harness has a p/n of 1C3Z-14A699-DA
The module is YL14-14C724-AA (I think that's the engineering #, but is still correct).
I've taken both of these to my local dealership and they have told me 'yep, they're right', but still don't understand why they don't plug into each other. When I asked what they would do if I brought the truck in to have them do this, they said.... ummmm we'd probably 'hard-wire' it .... Yeah.. I haven't been back there.....
I've spoke to Ed several times and he even put an inquire into FMC, but said he couldn't get any information back.
First question.. These are the correct P/N's? If so, why don't they work??? I understand that FMC doesn't like to help too much with modifying things. But if the truck had heated seats and I needed to replace these two parts for whatever reason, they should still work with each other???? Am I making any sense at all?? The harness has connectors for the motors (2ea) the heating elements (2ea) and the heater switch, they all match up and connect.
I hate like heck to pitch everything and go with aftermarket seeing as how I have several hundred $$$ invested already. I just wanted to have the OEM look. Yeah, hind-sight I would have went with aftermarket.
I have searched the threads, but haven't found anyone having a similar issue. If I've overlooked a post, please let me know.
Please let me know if more information is needed.
Thanks all
Thanks all
Seat Heater for Cars and Trucks from HeatedSeatKits.com
I've been running the cheap ones for the last few years and absolutely love them. If you don't have hog ring pliers or hog rings, spring the extra few dollars for the install kit. You can spend a little more and get the larger pad, but the regular one works just fine for me.
Thanks all
Thanks all
Any other help besides buy aftermarket ones? Like I said, I've got a few hundred invested so far with the heater switch, heater elements, wire harness, heater control module and the new plastic cover on the side of the seat (to hold the new switch). Thanks again!
If you're really wanting the factory stuff, check with Tousley Ford. They should be able to help you out and treat you right on the pricing. https://www.ford-trucks.com/forums/1...discounts.html
I have an early 99 Lariat that had power leather driver and manual leather passenger with no heat in either. I found a set of real nice seats out of 2006 or 2007 crew cab that way they didnt have the seat belts bult into the seats and crew cab had heated and powered on both seats. Best part is I got them for 200 bucks and they look like new! It was a direct swap into my pickup, the color is not right, but it is close enough for me. I had to add three wires to get it all hooked up but I love it.
I have the factory service manual for these trucks if there is anything I could look up that would help let me know.
I can tell you the power only seats have a 4 wire plug on the driver side and only uses 3 wires as I recal. The heated/power seat has an 8 wire plug that only uses 6 wires. When I bought my seats the salvage yard cut 6 inches off the other side of the harness so I had the pickup end too so I could splice into my pickup wiring and with the help of the wire schematic it was no problem. The passenger side has a 4 wire plug as well and only uses three wires that run over to the driver side connector.
Jeff
Jeff
Sorry I cannot help the OP but for what it's worth for others looking to do this another aftermarket kit is available from RockAuto and cheaper than the one Chris posted. I put this in my wifes car and she loves it. RockAuto Parts Catalog
Not sure how to link off their site apparently. It is under extras; body interior; seats
When I hook everything up and press the heated seat switch, the yellow/amber LED flashes for a half sec. then nothing..... Is this switch latching? I've even tried to hold the button in for a few mins. but didn't feel any heat. It only happens once and I have to unhook the Heated Seat Module and plug it back in again, then it will do it again.. only flash for a sec. then nothing.
If anyone is taking their heated seats out for any reason and wouldn't mind taking some pics. of the connectors, that might help verify I've got things right. Thanks for everyone's interest and help.
