proper coolant
I've been using Fleet Charge, Tractor Supply has it, its precharged with SCA's. If you want regular coolant, you can add the SCA's. Its been discussed ad nauseam... have you discovered the search feature?
Oooh ooh! I know this one......
Fleetcharge antifreeze comes with the SCA you need to prevent cavitation already in it. O'Reilly carries it, but you may find it other places as well.
There are also additives you can, well, add to regular coolants that do the same thing. Don't have names or PNs immediately available (sorry), but a bit of searching should turn them up. I'm pretty sure NAPA or your local Ford dealership sell them.
Mike
Mike
Thank you, I remembered reading on a post about a brand that already had the sca in it, and could'nt remember the name (fleet charge). Thanks again MudGuts. I would have spent more time searching on my own but dont get much time on the computer,between my concrete const, Bussiness and a store, the 2 keep me swamped.
Really?! Get with the program cavitation is an engine killer and one of the worst possible things that can happen to your engine and you should know this the. 7.3L International Harvester IDI is especially suseptable to this problem. If I were you I would do some research and and flush your system ASAP and add the proper coolant.
What is the diferance between EC-1 and SCA's
Cat EC-1 is just Caterpillar's spec for extended life coolant. How it prevents cavitation I dont know but Cat's OTR engines have been using it for years with the majority of them being squeeky clean inside the cooling passages. ELC is an organic acid coolant, no SCAs are required; just add the appropriate amount of extender (probably a pint in our engines) after three years or 300k miles and call it good for another three years. Motorcraft Gold coolant is similar, I just used the Cat stuff cause its available at most truck stops- no need for a Ford dealership. Maybe the Motorcraft and Cat are compatable; I wont say cause I dont know.
ThePriceLife
06-01-2018 07:33 AM
comingback2ford
07-14-2013 03:57 PM
