CHANGED OIL, TRUCK WONT START
2005 F350 SD Lariat FX4
I just changed my oil, now truck cranks, but wont start. Did I do something to the spring in the oil filter resivoir? Spring sticks when pushing down, then snaps down.. Should the spring move up and down freely?
Any thoughts would be appreciated
oil filter is supposed to be tightened to 19 ft / lbs. also, do not reuse the old o-ring on oil filter cap. use the new o-ring tat came wif it. make sure to spread new oil on that new o-ring.
oil pan gasket (drain plug bolt) is supposed to be tightened to 14 - 22 ft / lbs.
jim is right too. u have to use an oem oil filter cap as well.
It is absolutely a ford oil filter cap. I put Rotella T-6 Synthetic 5w 40 in it and I put in just under 14 quarts per the thread in the bible. I didn't have a torque wrench so i marked the cap and the hose in front of it and it seemed normal.
I will say this; I changed the fuel filters a couple weeks ago at most, when i picked it up and I am pretty sure thinking back that I lined the o-rings with diesel fuel insted of oil. That is bad right or wrong. Will eat it the orings? How long would it take?
