1997 Expedition. Blower only works on speeds 3 and 4. Works out of all vents and every other function works. I suspect the blower motor resistor? Does that sound right? If so, where is it located?
My 99 Expedition had heater motor problems, I found the connector that plugs into the resistor pack was melted. I ended up seperating the wires and adding connectors so it could be plugged in individually to each connection on the resistor pack. A pain in the neck as it is tough to see down there, but it works.
Your dad was probably getting a price for the temperature controller, not the speed resistor. Here's the prices over at Rockauto: RockAuto Parts Catalog
my rear blower is acting up....when you put it on "1", it blows hard like 3 or 4.
when you go over to "2" and up, its back to normal
any suggestions? sound like a resistor prob?
