Borg Warner CPS!
#61
I didn't have that problem. I took mine in on the recall and it has been working for 2 years now no problems. I keep a spare JIK but they also gave me back my old one.
#62
#64
#66
#69
This guy right here.. I caught him in the classifieds. Sent him a PM minutes after he posted it.
#70
OK... I've read everything. There was a question about heat way up the line and this is more relevent than most imagine. There are references to the thickness of plastic, and to the gap from the sensor to the gear. Here are some facts about hall-effect sensor magnets:
- Heat: Magnets work until they get hot, then they stop working - permanently. Variations of heat causes variations of gaussian loss (fancy-schmancy word for magnetic strength loss). An inexpensive magnet that is pliable/flexible for the manufacturing process has a max temp of 212 degrees F, then it begins to lose it's magnetism. The "really good one with the strong magnetism" might have a rare-earth magnet, which is good up to 284 degrees F. The flexible one is easy to work with, but the rare-earth magnets are very brittle and a bugger to shape. Somebody has to manufacture the magnet to fit in the head and based on what I've read about CPSs, nobody has contacted the right vendor yet. I work with hall-effect sensors all day and I know who makes the good ones for the equipment I work with.
- Time: Magnets weaken with time, heat near their limit, exposure to magnetic or strong electircal fields, and a few other factors we don't encounter in the truck.
- Distance. distance! distance!! Magnets lose their pull exponentially with distance. Say you have a 1/16" gap and you move the magnet to a 1/8" gap - you just lost 75% of your magnetic pull. All of our hall-effect sensors at work have threads and double-nuts to precisely set the gap and adjust the gap for time/vibration. That one item right there puts us Ford owners on the defence.
#71
#72
The one you get from your local Ford dealer or riffraffdiesel.com. The part number will be DU-87.
#73
