Seems like it's starving
Old 02-18-2012, 03:52 PM
79fordrat's Avatar
79fordrat
79fordrat is offline
Just recently finished getting my F100 registered, figuring it would be the best way to find any driveability issues. The truck sat for about 14 years before i got my hands on it.She starts right up, and seems to run good when it's sitting in the driveway, so that's a plus. after it warms up, the oil pressure drops to the low side of normal, and she's a bit ticky on the driver's side. It's a 400, so I figure it's just time for some bearings, isn't knocking or anything like that, just ticky. Here's the problem. Get going down the road, no problem. After a few seconds of acceleration, she acts like she's starving for fuel. It has a new fuel pump, so I know that's good. Could it be a restriction at the carb inlet, or possibly a clogged fuel pickup. Any help would be appreciated, thanks.
Old 02-19-2012, 06:42 AM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
Sounds like you're on the right track. No doubt the carb needs rebuilt after sitting that long. Surprised the gaskets aren't leaking. You''ll be surprised how much crap is in the fuel bowl after the old gas evaporated.
Old 02-19-2012, 06:55 AM
79fordrat's Avatar
79fordrat
Yeah, i figured i take a crack at the carb, first. I can only imagine the fun I'm gonna have trying to get the tank out. Also going to pick up a mechanical oil gauge so I can get an idea of where the oil pressure's at.
Old 02-19-2012, 03:14 PM
critterf1's Avatar
critterf1
critterf1 is offline
Check fuel pressure and volume at carb. Carb. should be rebuilt, probably full of crud.
Old 02-19-2012, 11:24 PM
tbear853's Avatar
tbear853
tbear853 is online now
Received 1,288 Likes on 1,089 Posts
Replace the fuel filter at the carb inlet.
Old 02-20-2012, 04:19 PM
79fordrat's Avatar
79fordrat
Yup, it was the inlet screen. Seems like the previous owner ran it without a filter, she was plugged tight. Running good now. Now, it's time to address other issues. Thanks.
Dads76XLT
07-28-2017 03:30 AM
dorf dude
02-17-2013 08:04 AM
jdlongmate
02-15-2009 02:04 PM
true
06-01-2007 01:39 PM
soundman502
27
03-09-2007 03:40 AM
Quick Reply: Seems like it's starving
