Go Back   Ford Truck Enthusiasts Forums > Misc. > Towing, Trailers & 5th Wheels
Sign in using an external account
Register Forgot Password?
Towing, Trailers & 5th Wheels SPONSORED BY:
  #1 (permalink)
Old 02-08-2012, 05:35 PM
RickBraden RickBraden is offline
Garage is empty, add now
RickBraden is starting off with a positive reputation.
What is my GCWR
I found decal on door jam & it lists Front GAWR 5200 lbs, Rear GAWR 6084 lbs, & GVWR 8800 lbs. I need to know what the trucks Gross Combined Weight Rating is to verify a 5er that shows 11,300 lbs. Thanks for any help.
__________________
'04 F250, 50 gallon fuel tank, Pre-luber, by-pass oil filtration, 4" exhaust with down-pipe, Only Rotella 5w-40 full syn.
  #2 (permalink)
Old 02-08-2012, 06:27 PM
dchamberlain dchamberlain is online now
dchamberlain has a spectacular reputation.dchamberlain has a spectacular reputation.dchamberlain has a spectacular reputation.dchamberlain has a spectacular reputation.dchamberlain has a spectacular reputation.dchamberlain has a spectacular reputation.dchamberlain has a spectacular reputation.dchamberlain has a spectacular reputation.dchamberlain has a spectacular reputation.dchamberlain has a spectacular reputation.dchamberlain has a spectacular reputation.
There are a lot of variables. Engine, cab, gears, type of trailer, etc. There are tables in your Owner's Manual. However, assuming from you're sig that it is a 6.0L, I believe in '04 it's 20k.
Get your Owner's Manual here. If you have the diesel, I think it'll be in the Diesel Supplement.
https://owner.ford.com/servlet/Conte...ionalEventPage
__________________
David Chamberlain
2004 F-250 SD, 4x4 FX4, 6.0L PSD
Oregon Chapter Member:
To join the Oregon Chapter, click HERE
  #3 (permalink)
Old 02-08-2012, 07:10 PM
Thanks David. It was all right there. It says the GVWR is 20K. The bad thing is it shows Max trailer weight is 10,600 lbs. Mine is 11,300 lbs. I guess I messed up & took the word of the RV salesman back in '05 when I bought used 5er.
__________________
  #4 (permalink)
Old 02-08-2012, 07:16 PM
Is the 11,300 dry weight or is that all loaded up?
Your truck will pull that trailer. Technically it's over GCVR, but if you have good brakes and a good controller, and the trailer isn't too front heavy, you'll be fine.
I've pulled at high as 15.5k but I wouldn't want to do that every day. I've pulled 13k without any trouble. Both were a gooseneck.
__________________
David Chamberlain
  #5 (permalink)
Old 02-08-2012, 07:23 PM
RV_Tech's Avatar
RV_Tech RV_Tech is offline
RV_Tech has a very good reputation on FTE.RV_Tech has a very good reputation on FTE.RV_Tech has a very good reputation on FTE.RV_Tech has a very good reputation on FTE.
Quote:
Always good to get the actual weight. You may be pleasantly surprized.
Steve
__________________
RVDA/RVIA Master Certified RV Technician
You think you're confused?
2002 F350 Dually, Rhino Liner, Edge Evolution (running in stock mode), 4" exhaust, 6.0 cooler
2010 F150 super cab, box stock, bed slide, ARE bed cover
  #6 (permalink)
Old 02-08-2012, 07:55 PM
I've pulled it to Orlando & back in 05 & it was like a dream. I will take it to a scale before I trade in for lighter one. I just remember the tag on trailer was 11,300 lbs. I'm not sure what the label said. I'll double check it. Thank you both.
__________________
  #7 (permalink)
Old 02-08-2012, 08:14 PM
RV_Tech's Avatar
Outside tag is gross vehicle weight rating, i.e. max weight. Not everyone runs at their max.
Steve
__________________
  #8 (permalink)
Old 02-08-2012, 08:48 PM
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Diesel Cowboy
texastech_diesel has much to be proud oftexastech_diesel has much to be proud oftexastech_diesel has much to be proud oftexastech_diesel has much to be proud oftexastech_diesel has much to be proud oftexastech_diesel has much to be proud oftexastech_diesel has much to be proud oftexastech_diesel has much to be proud of
2004 FORD SUPER DUTY SPECIFICATIONS
It's that low 8800# GVWR that gets you on those years, early F250's were severely under-rated trucks. I've pulled more than 25k combined with an '04 F250, but like David said, not an all-day-everyday, or even a comfortable situation, just a must-do involving live animals in a trailer. Come in under all the axle and GVW limits and drive smart.
__________________
Bryan- 2007 F-250 6.0L PSD FX4
<a href=http://www.ford-trucks.com/forums/image.php?type=sigpic&userid=412675&dateline=1231016145 target=_blank>http://www.ford-trucks.com/forums/im...ine=1231016145</a>
295-70R18 Nitto Trail Grapplers, Ranch Hand Legend, Edge Insight CTS
Isspro EV2 gauges, PHP Atlas 40 FICM Tuning
, Dfuser Coolant Filter
  #9 (permalink)
Old 02-08-2012, 08:58 PM
Thanks for the GTW. I will weigh trailer like it usually is & weigh to make sure I don't exceed the Gross Rear Axle Rating.
__________________
  #10 (permalink)
Old 02-08-2012, 09:02 PM
I think with what you've said so far you are OK. You should check to make sure you aren't over your rear axle rating and make sure you're running properly inflated load range E tires.
What I found was too much weight at the front of the trailer made the truck sag in the rear and it didn't drive as well. If the truck is mostly level you're in good shape. If it's sagging and you aren't over the rear axle weight rating, then consider air bags to help level the truck out.
__________________
David Chamberlain
  #11 (permalink)
Old 02-08-2012, 09:16 PM
David, Funny you mention the air springs. I bought a set for my truck about 2 months ago. Still in the box cause I workmostly 7 days a week. I will put them on before I tow it. Then I'll weigh the axles & the 5er. Thanks & take care. Rick
__________________
  #12 (permalink)
Old 02-09-2012, 07:06 AM
senix's Avatar
senix senix is offline
senix has much to be proud ofsenix has much to be proud ofsenix has much to be proud ofsenix has much to be proud ofsenix has much to be proud ofsenix has much to be proud ofsenix has much to be proud ofsenix has much to be proud of
What I do and did was check my axle ratings and tire ratings and GCVWR.
Stay within all those and you are fine.
find the nearest cat scale and get your certified wt ticket and stick it in the glove box
CAT Scale
__________________
Scott-2008 F250 PSD Crew Cab 4x4, 12K GVWR,
Cooper Discovery STT LT275/70R18's
Banks Ram Air & 6-Gun, Ravelco Alarm System, Frontier Extreme FT. Bumper
2011 40' 4-slider stoneridge 5th wheel coming in at 14K
  #13 (permalink)
Old 02-09-2012, 11:36 AM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
2008 Ford F-250
TexasRebel has a very good reputation on FTE.TexasRebel has a very good reputation on FTE.TexasRebel has a very good reputation on FTE.
8,800 + 11,300 = 20,100
With that trailer, your GCVWR is 20,100#
The issue is with the pin weight. If the weight of your pickup + the pin weight is more than 8,800# you break your GVWR.
__________________
2008 F-250 XL 5.4L Reg. Cab 4x2 6-spd 4.10 w/B&W "Turnoverball"
OE Options installed: TowCommand Brake controller, Upgraded to 4 spkr. Single CD/AM/FM w/AUX from 2 spkr. AM/FM, cab clearance lights, Fog Lights, Cruise Control, Redundant Audio Controls.
  #14 (permalink)
Old 02-09-2012, 05:15 PM
You are correct. I'm hoping I don't exceed the 8800 # with with 5er connected. My 5er is a nice used unit I got in '05. It was built in about '93. It has one big long slide-out. I bet the newer ones are probably lighter & more costly.
__________________
  #15 (permalink)
Old 02-12-2012, 09:12 PM
Bigpipes 35's Avatar
Bigpipes 35 Bigpipes 35 is online now
Bigpipes 35 is gaining momentum as a positive member of FTE.
I have also read that the GCVWR is not a legal number but a suggestion number by ford in the owners manual , The legal number and what the dot looks at is the numbers on the door concerning your front and rear axle weights and your vehicle GVWR which in your case is 8800.
__________________
2003 F250 fx4 cc short box. 5.4 , 4.30 gears, flowmaster 50 , spd Y pipe , eagle alloys , 285/70/17 nitto terra grapplers, SCT X3 tuned , warn manual hubs, 6.0 trans cooler mod
2000 f150 4x4 work truck 4.6
Tags
2004, 60, colorado, combined, diesel, duty, f250, f350, find, ford, gcrw, gcvr, gcvw, gcwr, gross, rating, super, table, vehicle, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
