You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Does any one know if there is a way to use smaller brakes on the cv .ifs.Reason I'm asking is I dont what to use 17 inch wheel,like to stay with my stock 15" rims and this truck does not need 12 in brakes.
What year CV? If you are talking about the '03-'11 you are required to run 16" not 17" & you may be able to get 15" custom built to clear the calipers. The other option that pops out right away is use a different IFS. The 12" dual piston caliper front brakes are great! I would rather have too much stopping power than not enough.
ive never really looked into a smaller brake setup for the panther IFS, althow Im sure something is possible you would have to figure out a caliper bracket that would work out on that setup or have one machined.
But with that being said if its the classic 15 wheel look is what you want this is truely the wrong IFS for you. other than the big brakes this front end is very wide compared to your stock setup and if you were to put stock offset wheels on it or anything close they would stick way outside the fenders. you would have to run a modern wheel that tucks the tire in more, which is available in a steel wheel. some of the earlier CVs had 16 steelies that had a lip for hubcaps and still had a decent offset for the panther.
__________________ LeadFoot C.C.
1960 short bed fleet side with
03 crown Vic Panther IFS, 2V 4.6, custom cold air intake, Typhoon manifold, 2.5" exhaust no cats with 40 flowmasters, underdrive pullys, Patriot Performance Blower Cams, Comp valve springs, 100 wet shot nirous, custom dyno SCT tunes, 4 speed Auto, 373 gear 8.8 track lock rear end, 4 wheel disc, and linelock.
