2001 F-250 7.3L turns over but won't start!
I tried to start my 2001 F-250 SD 7.3L diesel and it turns over quick but won't run. It sounds like it's not getting enough fuel(dry sounding..if that makes sense) I changed the fuel filter, air filter and went ahead and changed the oil too(wasn't over miles but it's been a while since a change). Tried using a code reader but it either shows "error" or "0". I read that there could be issues with the CPS so I went ahead and bought one and when I went to replace it, I noticed the wires to the CPS were cut off! Problem discovered, right? I wish. I used some displacement connectors and tried to fire it up and still the same. So I replaced the CPS as well since I already bought it. Still won't run. I'm trying to avoid paying for a tow to a shop and trying to fix it myself but don't know what else to check. Any help is greatly appreciated!
There are several things to check with a crank-no start situation, but since your Cam sensor wires were cut, this must have caused your issue in the first place. It will be difficult to diagnose without getting a scanner to read the PCM data. You can check out this website https://oregonfuelinjection.com/serv...l-diagnostics/
If you had a scanner that could read data, you would be able to see whether or not the cam sensor is being read. Without a scanner to verify, I would recheck your spliced wiring connections you made to make sure they are making good clean connections
texans
26
09-02-2011 05:31 PM
kdokey
07-04-2009 02:01 PM
doubleu1964
02-15-2006 01:59 PM
bhd
22
09-22-2005 10:38 AM
