idi turbo wont start
I have a 93 F350 IDI turbo that runs fine once it starts but it seems not to be holding fuel in the pump to start. Is there a check valve in there that goes bad and let's fuel drain back down or something? It will crank and crank and not start. Is it time for an electric fuel pump?
Sounds like a comon problem you probably have an air leak in your return lines, they are made of rubber so are the o rings that fit on your injectors so some where in your lines you have an air leak it won't leak fuel just suck air when it sits overnight then it won't start in the morning.
I've only had it two weeks and its happened about four times. Today it did it at the mechanics and he said it wasn't holding fuel in the pump. He got it started, I drove it home and about fortune minutes after shut off I tried to start it and the same thing. I'll check those return lines, that sounds the bestcstarying point. How many are there, two? Are they from the pump down the rail to the tanks?
Get someone to turn it over, use a 5/8" inch wrench to crack the two rear injectors when it starts spurting fuel close them and then start the truck. Also there is a check valve in the filter head but iirc it keeps fuel from going back into the fuel return lines, I doubt that is your problem. Some guys go to an electric fuel pump but it isn't like a gas engine air in the system will keep the engine from starting so having an electric fuel pump isn't going to solve that problem. I will try and find a picture of the return lines.
https://www.ford-trucks.com/forums/1...p-6-9-idi.html
A lot of good info on return lines in this thread.
https://www.ford-trucks.com/forums/1...ne-repair.html
This one should give you an idea
Received 3,114 Likes
on
Good call TJC I think you are right there. Air intrusion problems all around. The good news is it is a pretty cheep fix.
Yeah I can't remember how to get the cap off of the rear tank but there is a filter in there and two tubes one is a return line one is the line to the lift pump. It is made of hard plastic and you will see a crack in the lift line.
