Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
1948 - 1956 F1, F100 & Larger F-Series Trucks Discuss the Fat Fendered and Classic Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 02-03-2012, 11:13 PM
underthebridgejim's Avatar
underthebridgejim underthebridgejim is online now
1950 Ford F-1
underthebridgejim is gaining momentum as a positive member of FTE.underthebridgejim is gaining momentum as a positive member of FTE.
Lap Belts & turn signals - check!
Finaly got around to installing turn signals, and lap belts. I could have saved myself several hours of wasted time if I had only remembered that I had LEDs in the back, and done a search on them. If I had I would have known that LEDs will not work with a regular flasher, as they operate by the heating and cooling of a piece of metal contained within them (this was clearly stated in the old thread I found right here on FTE). Oh well live and learn. OK to be consistent I changed out my front lites with direct replacement LEDs, got a LED flasher and wow, they worked, I even have emergency flashers. I also installed a set of lap belts bolted to/thru the cab floor useing the supplied hardware, Its probably suficient, but I will probably beef it up some more when I clean and paint the bottom of the cab, just for piece of mind.
__________________
Jimmy / 1950 F-1
  #2 (permalink)
Old 02-03-2012, 11:28 PM
KJLYPW's Avatar
KJLYPW KJLYPW is offline
Garage is empty, add now
KJLYPW is starting off with a positive reputation.
Lookin good Jim, same switch set up as mine, works good but have become a bit of a spoiled old fart, I often forget to turn the darn thing off after turning a corner. Get pretty use to the auto off feature on my regular driving truck
__________________
Kevin L.
93 F350 7.3 IDI 4x4, E40D with Multi Disc TC, Ram air, Stans Headers, 3" to Y- 4" exhaust,3.55, B&M shift plus, Pyro, Fuel opened 1-1/2 flats- Happy with power increase!
48 F-68 Nut and bolt restoration/mods-power brakes, 16.5" 8 bolt wheels, reds headers, signal lights and seat belts.
  #3 (permalink)
Old 02-03-2012, 11:36 PM
Dano78's Avatar
Dano78 Dano78 is offline
1956 Ford F-100
My Garage
Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.
Nice job Jim! Even though those turn signal units aren't necessairly factory, for some reason they just look right at home in these trucks.
  #4 (permalink)
Old 02-04-2012, 02:35 AM
55 f350's Avatar
55 f350 55 f350 is offline
1953 Ford F-100
55 f350 has a very good reputation on FTE.55 f350 has a very good reputation on FTE.55 f350 has a very good reputation on FTE.
i agree with the turn signals looking at home . same aftermarket unit my 53 has / had when i got it . got two sets of factory ones now from different old rust buckets that gave up parts for it .
__________________
that's because were all opinionated bullcrap artists looking for somewhere to espout our views and show the world how much we { don't } know especially to newcomers. were on a mission to impress you and make you believe we are all knowing ! yes i am slightly left of center and i am bent on world conquest !!!!!!!! P.A.D.D = project attention deficit disorder . everyone on here has it , and is an enabler !!!! so enter at your own risk !!!!!!!!!!!
  #5 (permalink)
Old 02-04-2012, 10:09 AM
Moe Craig's Avatar
Moe Craig Moe Craig is online now
1949 Ford F-Series Pickup
Moe Craig is starting off with a positive reputation.
Moe Craig
Looks good... Hope your enjoying the ol' girl
__________________
Moe Craig
1949 Ford F1
"You don't know the power of the Darkside!"
  #6 (permalink)
Old 02-04-2012, 11:16 AM
HarleyGyrene's Avatar
HarleyGyrene HarleyGyrene is offline
HarleyGyrene is starting off with a positive reputation.
Very nice ! Both of those items are on my ever growing project list. Looks great !
__________________
Jake
Semper Fi !!
'56 F100 Darkside
'56 F100 NAPCO 4x4
'97 Harley FLSTC
  #7 (permalink)
Old 02-04-2012, 11:22 AM
Nighthawk756's Avatar
Nighthawk756 Nighthawk756 is offline
Nighthawk756 is starting off with a positive reputation.
Lookin' good man!!
  #8 (permalink)
Old 02-05-2012, 09:15 AM
BadAss Beaver's Avatar
BadAss Beaver BadAss Beaver is offline
1954 Ford F-100
BadAss Beaver is gaining momentum as a positive member of FTE.
Two more things scratched off the list huh Jimmy! Lookin' sharp my man!
__________________
Jon
Beauty is a curvy body with big headlights.
1954 F-100. View the build progress at http://classictruck.shutterfly.com
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
