First Tow with F150 HD
I don't know what to say except......awesome. My 2012 F150 HD 5.0 pulls my trailer SO MUCH BETTER than my F250 it's like night and day. 1200 mile trip from Michigan to Florida and it pulled strong and comfortable. Much stronger than my F250 and even squats less with the 670 lbs of tounge weight. Trailer weighs in at 6500-6700 lbs.
Gas mileage was pretty good considering a STRONG headwind all through Ohio, Kentucky and much of Tennesee. Ended up at 9.2 mpg for the 1200 mi. after being as low as 8.5 mpg average with the headwinds. She pulled the average back up after the wind let up. Could likely see 10 mpg without wind. First two tanks were hand calculated and were within .1-.2 so I quit. Guess it ain't a lie-o-meter anymore.
The 5.0 pulls real strong and has no trouble keeping up with traffic or passing etc. Holds cruise well and just drops down a gear or two to pull all hills encountered with no problems. The trans shifted smoothly and ran no hotter than 202*. On the biggest grades encountered she dropped down to 3rd gear and then powered up the hill shifting as she climbed. It didn't sound bad like it was over reving at all. This engine is sweet.
The factory trailer brake conroller is so good awesome doesn't go far enough to describe it. No more jerky stops like my Tekonsha in my F250.
Over all I think I ordered exactly what I needed for a tow vehicle. Great truck.
Mike
The shifting does take some getting used to...This 2011 F-150 is my first brand new vehicle ''3rd overall'' and the first one with a 6-Speed auto. But after the 8800 miles I've put on the truck since I got her, I've gotten well used to the 6-Speeds shifting habits and honestly don't even think about it anymore.
I pulled my trailer 15 1/2 hours Tuesday and although a long day the F150 was what made it doable.
But I do feel the consequences of the HD payload springs. It does tend to bounce over uneven road surfaces a little more than a regular F-150 would. It just doesn't bother me much, it was expected.
That's the beauty of these transmissions. You can manually shift them if you want, you can lock out gears, or you can let them shift. I prefer to let the trans do the shifting.
I understand where you're comming from...My old 1990 F-150 I had back in highschool with the old pushrod 5.0L EFI and AOD 4-Speed auto (3-Speed with Overdrive really) didn't shift as much as my 2011 does. But the difference is that my old 1990 would pretty much require full throttle to hold even the speed limit on small grades (and pulling the same weight) that my 2011 5.0L 6-Speed can walk right up in 5th or 6th gear doing less than 2,500RPM's.
I guess i don't like the way it is always trying to grab the highest gear possible, because then it has to downshift caus it can't pull any kind of hill.
i dunno .. i guess that's why i asked ... must just be me.
if my 2010 had select shift, i could see myself locking out all the OD gears all the time ... that way it wouldnt have to shift.
I think it would be fun to drive it for a month locking out 6th alltogether, and just see what the mileage difference is. I'm betting it woulnt be as much as lead to believe.
That being said it rides lots better than my F250 and I've had people comment " this truck rides good, not what I expected from a 3/4 ton" about it.
