2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Need a picture of a part, I have the number
Old 01-28-2012, 01:32 PM
cop on my back's Avatar
cop on my back
cop on my back is offline
I had my 08 looked at by the dealer and I need part #7L1Z 14C724 B This is a seat heater/motor. Thing is, it doesn't match the numbers on my heater motor or control box that is under the seat. Any Ford guys out there with access to a part diagram? I have googled the number and get close, but no pics.
Old 01-28-2012, 02:36 PM
cop on my back
After more research, it would appear this is the lower fan assembly. I think the heating element is toast.
Old 01-29-2012, 09:05 AM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
Try this.
Front Seat Pads/Valances & Heating, 2007/From: 08/02/2006; With Bucket Front Seats, With Temp Control Passenger Seat, With Temp Control Drivers Seat
There is an upper and lower heater fan assembly.The part number you gave is just the lower.
BUT.......
There is a control module also, part #9U5Z-14C724-B (old part # 7L1Z-14C724-C ) so it get confusing on what part you need.
What numbers are on the part in the vehicle or going by the diagram what part do you need?
Matt
Old 01-29-2012, 09:33 AM
cop on my back
Thanks for that. The dealer specified that number. I took the seat apart and ran the heating and cooling with the fan assemblies loose and the lower one does not produce heat. Although they only work for about 15 seconds, the upper one does produce heat.
I think the cause was the fact there is no air filter on the lower one and there was lint in the heating/cooling element. Judging by the discolouration I would say the element got too hot due to the lack of air movement and got damaged.
I contacted the manufacturer, Amerigon, to see if I can just get the Thermal-electric device and solder it in myself. I don't expect that will work as they have produced over 14,000,000 of these and my little request for one will be so far off the radar it would be a cold day in hell before I got it.
I will likely get one from a dealer in the States as they are way expensive up here in Canada.
Old 01-29-2012, 04:52 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
You say it only stays on for 15 seconds? Does the passenger side heat work? Both top and bottom ? Just a thought but have you tried switching the module PS to DS ?
Matt
Old 01-29-2012, 04:58 PM
cop on my back
Yes, stays on for about 15 seconds and then when you try to turn it back on the indicator lights blip for just a split second and won't stay on. If you cycle the key off and on again you can turn it back on for another 15 seconds and it repeats. This appears to be the way they all do when they fail from what I have read.
During that 15 seconds the upper unit produces heat, the lower does not. Again, with the discolouration in the element in the lower unit I suspect that is the problem. I have not tried to swap out the driver's side, don't feel like undoing another seat if I don't have to. Besides, when the dealer ran a diagnostic on the system it pointed to the passenger side lower fan assembly unit.
schmiddw
08-19-2018 07:23 PM
madsonp
6.7L Power Stroke Diesel
10-02-2013 10:49 AM
madsonp
1999 to 2016 Super Duty
09-30-2013 10:49 AM
moose_j9
1997-2006 Expedition & Navigator
12-04-2010 09:44 PM
66gpw
02-08-2007 08:33 PM
Quick Reply: Need a picture of a part, I have the number
