Really, this much work for an alternator??
My alternator went out on me today. Looks like the regulator went bad, things are smoked on it.
I can't beleive that some idiot would design and a company would actually produce a product so poorly thought out! First off, who puts an alternator (a very vital and important electrical component mind you) down right next to the wheel well; where rain, snow, salt, liquid de-icer, etc, can get to it!!?!?
To continue off that, you can barely get to it to get it disassembled from the mounts since it's below the battery, IC pipe, wiring harnesses. Next to find out that there's no room for it to come out. So I called the local Ford dealer to price a new one and see if there was a trick to getting it out. A new one is $628!!! and that's with me giving them my core!! Then the service guy got into what it takes to get it out, basically disassembling most everything on the left side of the engine. I ended up pulling the battery, battery box, intake box, cut loose all the wiring harnesses from the keepers, and can only move the IC pipe out of the way since they designed that so poorly as well.
I'm just pissed cuz it takes so much work for a silly alternator. Makes me want my '99 7.3L back!!! 3 bolts, pull the wires and belt off it and it comes right off!
Rant over.
OR you could remove the right hand fender splash shield and remove and install the alternator in about 30 minutes like the Ford Work Shop Manual says.
Disconnect the batteries. For additional information, refer to Section 414-01.
Remove the air cleaner assembly. For additional information, refer to Section 303-12.
Remove the fender splash shield. For additional information, refer to Section 501-02.
Rotate the accessory drive belt tensioner clockwise and remove the drive belt from the generator pulley.
Remove the nut and position the generator B+ terminal aside.
To install, tighten to 12 Nm (9 lb-ft).
Disconnect the generator electrical connector.
Remove the 2 lower bolts to the generator.
To install, tighten to 47 Nm (35 lb-ft).
Remove the upper bolt and the generator.
To install, reverse the removal procedure.
I got it out and changed. Bought a used one from a local junkyard for $160, no core, w/6 month warranty. Figured for those dollars I can tear back into the truck again now that I know how.
In the meantime, I'm tearing apart my whole intake assembly and will probably be doing some 'needed' upgrades: EGR delete, new passenger IC pipe, CCV mod. Everything was crap full of oil. Pulled the CAC and when I pulled the bottom boot it drained oil for a little while.
ordered new one today same make that came in truck
(200 amp foreign made) I will post part # & make
(P.A.S.C.O. $436.87 no core charge) they are changing pully from old to new, I will put back in tomorrow
Disconnected batteries, Removed right front tire, Pulled right fender splash sheild, removed belt, removed bolts, removed wires, pulled generator out, 2 hours,
(215 amp foreign made) I will post part # & make
88_F0RD
12-06-2016 07:53 AM
ramblincowboy
12-09-2007 07:34 PM
usmccorrections
01-30-2004 05:15 AM
