Starting DD project, making my 96' ECSB 2wd 3/4 ton a 1/2 ton. The rear swap will be easy but I'm unsure about the ifs. Will the beams swap right out or are there differences? I know the ride height is lower but anything else?
I'll explain the "why" when I start the project thread. The 1/2 has bent I beams to make it lower which is what want. Can the entire beam, hub assembly be swapped?
Measure from the spring mounts to the eye of the beam hinge. Also, measure the distance between the two hinges. If these match, you should be able to swap them out. You should also see if the cross member is going to give you a bind. What engine is the 3/4? Mine has a 460 and it has a different crossmember and subsequently different hinge mounts than a half or 3/4 with a smaller engine.
This project smells like a lowered 3/4 gone 1/2. I understand wanting the rim options of a 5 lug, but why start with a 3/4? And is it a 4x4?
Hey Joe. I've got a set of 2wd 1/2 ton beams at home and my F-250 is 2wd. If you don't have both sets sitting there to measure, I can measure them for you. I'm pretty sure it will all bolt up though.
Thx Travis, I've got both, I'm pretty sure the lengths are equal, the bolt hole in the pivot is the main concern.
ANYBODY GOT A GOOD ANSWER FOR THIS I WANT A FIVE LUG PATTERN ON MY 90 F350 2WD CREWCAB AND LOWER IT 2-4 ANYBODY DONE THAT. CAN I JUST SWITCH OUT FRONT SPINDLES AND GET 1/2 TON REAR.
I hope to find out in the next few weeks. I'll link this thread when i start.
