1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Abs control module replacement
Old 01-25-2012, 06:10 PM
SuperMike's Avatar
SuperMike
SuperMike is offline
I am getting ready to replace my faulty abs control module. The service manual says to remove the HCU to replace the module. I want to know if there are any tricks to remove the module without having to disconnect the HCU so that I don't have to get the HCU bled.
Tonight I was look in the engine compartment and I was thinking that I could remove the driver side headlight and then cutting an access hole through the steel panel behind the headlight.
Any ideas??
wiredgeorge
05-19-2019 06:47 PM
7.5GasHog
32
03-05-2018 03:45 PM
clipnclop
1997 - 2003 F150
07-09-2007 08:45 PM
Quick Reply: Abs control module replacement
