2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
HVAC door flapping
Old 01-24-2012, 06:26 PM
cheese4420's Avatar
cheese4420
cheese4420 is offline
HVAC door flapping
I'm hearing what sounds like a door flapping coming from the very center of my dashboard. The outside temp was 68 and the internal temp was set to 68. I did not have the AC running and had it on face/floor blend with the fan on the lowest setting. My wife was driving and what seemed to be random times there was a flapping sound coming from the dash. It sounded like a plastic flap or door was bouncing or flapping like a screen door flapping open and closed on a windy day. I switched the vent to just face and it continued. I then switched the air completely off and the flapping still continued. This just started happening and I'm not sure what it could be. Does anyone have any suggestions? I would like an idea before I take it in to the dealer because since it does not happen on cue, it is more difficult to reproduce, diagnose and repair.
Thanks!
2012 Expedition Limited, 4wd.
Old 01-25-2012, 11:11 AM
berry1234's Avatar
berry1234
berry1234 is offline
It sounds like the blend door is broken. Does it happen when you turn on/off the recirculation button?
Old 01-25-2012, 02:46 PM
cstanley44's Avatar
cstanley44
cstanley44 is offline
If its like whats in my Explorer the recirc door and blend door are different doors.
The blend door blends hot and cold air
The recirc door opens and closes outside air
Ive had the recirc door replaced under warranty in my 04 explorer, a $49 part, and $700 labor! Its broken again, but not under warranty so I just removed the door.
Old 01-25-2012, 02:52 PM
berry1234's Avatar
berry1234
cstanley is right. The recirc door lets air in from the outside. See if operating this makes the noise go away.
Old 11-11-2012, 06:22 PM
cheese4420's Avatar
cheese4420
Well, it's broken again. Maybe this time they won't scratch the dash up when they replace it. Any idea how to keep this thing from breaking? Leave system on or turn it off? Has anyone else had this problem on the newer model Expeditions? I've seen posts on models which are five years old but nothing on the new models?
Old 02-01-2013, 03:48 PM
Craig.Parks's Avatar
Craig.Parks
Craig.Parks is offline
cheese4420,
This has just started occurring in my 2009 Expedition. It seems to happen when temp is turned down to 60. Where you able to get yours fixed?
Thanks,
Craig
Old 02-15-2013, 08:18 PM
cheese4420's Avatar
cheese4420
I've gotten mine done at the dealership as it was covered under the warranty. After really pressing my service manager, he said the only recommendation he had was to keep it out of the sun when parked. He said the extra heat causes the grease to rout of the gears and they strip out. I just moved from Phoenix to Chicago and when switching from AC to heat in the rear, the rear controller went out. What top notch engineering is all I can say about all of it.
Old 02-18-2013, 08:06 AM
Craig.Parks
Yep, I had to replace the rear controller in our '05. You would think they could fix the issue by now.
tim432
1999 to 2016 Super Duty
10-14-2013 03:32 PM
greenterror
1997-2006 Expedition & Navigator
06-22-2008 11:54 AM
Joker50
05-28-2008 03:29 PM
Quick Reply: HVAC door flapping
