King-Seeley Water Temp Sender
Besides MAC's, does anyone know of a supplier of the King-Seeley Bi-metal water temp senders? They run in reverse (ohms-wise) of the post-56 (or '7) type. I'm trying to resurrect my 51 and 50 water temp gauges, and the 60-70's senders sort of work except hot is cold !
8A-10990 .. Temperature Sending Unit-Two Terminals / Obsolete
1948/53 239 Trucks / 1949/53 239 Passenger Cars.
8A-10884 .. Temperature Sending Unit-One Terminal / Obsolete
1948/55 I-6, 239 & Y block Trucks / 1949/55 I-6, 239 and Y block Passenger Cars.
There are a few of each of these senders available NOS (I'll list the souces if interested), but Dennis Carpenter (800-476-9653) has both of them, prolly made in China repro's.
Note: The 1956 temperature sending unit is 1956 only and was used in all I-6 & V8 FoMoCo vehicles.
ford 99A 10884 temp sending unit
Hi, I saw your old post about temp sending units? I am looking for a ford 99A 10884 if you had any thoughts on where to find one, I would greatly appreciate it.
Dj
Dj
239 flatty: Two different water temperature sending units are used in 1948/53 trucks and 1949/53 Passenger Cars, one in each head.
Yes, the 2 post is an "on/off" switch. In normal operation, the switch is "on" allowing the temperature reading from the single post to flow through the dual post to the gauge. If the dual post gets to hot, the switch goes to "off" which causes the gauge to go to it's rest position of "H".
cbquinn66
04-04-2017 12:03 PM
chatterjj
10-29-2009 12:24 AM
myowneq
06-10-2005 09:42 AM
