300 Cubic Inches?????????
Old 04-20-2003, 02:08 PM
rustyolred27's Avatar
rustyolred27
rustyolred27 is offline
WHAT ARE THE MOST AMOUNT OF CUBIC INCHES THAT CAN BE PUNCHED OUT OF A 300 I-6??????
Old 04-20-2003, 02:33 PM
78 4X4 Thunder's Avatar
78 4X4 Thunder
78 4X4 Thunder is offline
i wouldn't go more than about .060 over, because it is already a 4" bore. So unless you want some really big pistons, i would only go like .030 over and shave the heads like .010 over.
Old 04-20-2003, 02:35 PM
rustyolred27
so how many cubic inches will that combo give me?
Old 04-20-2003, 04:03 PM
StrangeRanger's Avatar
StrangeRanger
StrangeRanger is offline
300s can theoretically be bores to +.060, which would yield 309 CID. But the block is a thinwall casting and you should get it sonic checked before going that far. Holding the overbore to a bore realistic +.030 gives 305 CID.
Boring is a very impractical way of increasing displacement.
Clifford offers (or at least used to offer) a stroker kit that took the stroke to 4.375 which gives 330 CID with a stock bore, 335 @ +.030 and 340 CID @ +.060. With that much stroke forget about making high revs and count on having to do a lot of head work to get it to breathe. Dealing with Clifford there's also the issues of price (high) and delivery time (glacial).
Old 04-20-2003, 04:09 PM
broncr's Avatar
broncr
broncr is offline
...is what you get at .030 over. Mine is 309.2 @.060 over (maximum overbore on a 300). I would have gone .030 over (or LESS), but the block was already at .040 . The more you bore, the less cylinder wall you have left which can create problems. If you go with the minimum bore you can spend your H.P. $$$ elsewhere (cam, carb/ intake, head, exhaust, ignition, gears ) . Then if you ever need to, you can bore it AGAIN.
Old 04-22-2003, 07:27 PM
MEPR's Avatar
MEPR
MEPR is offline
mine i think is .050 over and i think its about 307.5.
Old 04-22-2003, 09:46 PM
broncr's Avatar
broncr
broncr is offline
It's a TAD over 1.5 cubic inches PER .010 overbore. The geometry give you less for the 1st .010 and more for the last, but for all practical purposes - that's close enough.
Old 04-23-2003, 06:34 PM
Silver Streak's Avatar
Silver Streak
Silver Streak is offline
A few years ago I wasted some time dreaming of a huge 300. Using a resleeved block with 400 SBC pistons and some creative crank grinding I think I finally got it to around 380 cubes. The down side was that it would cost several thousand dollars to actually do, and it wouldn't rev like somebody already said. It might not even be possible. Adding displacement is a horrible return on the dollar performance wise. The only practical time to spend money specifically for an increase in displacement is when driveability is limiting power production.
Old 04-24-2003, 09:56 AM
Vampiro's Avatar
Vampiro
Vampiro is offline
you can go .060 over to 309 or you can go .030 over just to raise compression to 9.5:1 or 10:1 and have more power. mjust a thought. i wouldnt go more than .030 which is 305
redzepp35
New Member Introductions
09-15-2006 04:22 AM
rustyolred27
03-30-2003 07:59 PM
iron_cojones
03-20-2003 06:33 PM
fatforty
01-24-2001 05:29 AM
canadianfordman
Modular V8 (4.6L, 5.4L)
01-20-2001 12:42 PM
Quick Reply: 300 Cubic Inches?????????
