Stong smell of unburned diesel from exhaust (not inside the cab)
Old 01-18-2012, 08:19 PM
98SurplusExpy's Avatar
98SurplusExpy
98SurplusExpy is offline
For awhile now, I noticed a strong smell of unburned diesel coming from the exhaust. I don't smell this inside the cab; only at idle if I step out of the cab.
The smell is such that random folk have commented about it and suggested that I had a sticking injector ... but I have no symptoms of such, fule mileage is on par w/ other 6.0's, & I have no codes. My truck is stock other than a coolant filter.
Anybody else getting a strong scent of unburned diesel at idle??
Old 01-18-2012, 09:12 PM
w_huisman's Avatar
w_huisman
w_huisman is offline
Theres no way to know for sure if the smell is the same as mine over the internet, but a new EGR valve fixed it for me when my exhaust smelled like what you described.
Old 01-19-2012, 04:42 PM
zhilton's Avatar
zhilton
zhilton is offline
Fuel mileage is only part of the equation for checking for a leaking injector. Does the truck act like it's got a miss? If you've got an injector leaking a contribution/balance test with an AE will show which one it is. How about smoke out the tailpipe?
Old 01-19-2012, 07:40 PM
98SurplusExpy
Engine runs pretty smooth ... only a romp & puff of smoke during a real cold morning start. No contribtion codes ... but I hadn't had a contribution test done in awhile.
Old 01-19-2012, 09:20 PM
zhilton's Avatar
zhilton
zhilton is offline
I'd get a contribution test run if your getting a strong smell of diesel out the tailpipe. Could have a cracked injector that's leaking excessive amounts of fuel. Left alone long enough might hydrolock,
Old 01-20-2012, 08:37 PM
jchampion116's Avatar
jchampion116
jchampion116 is offline
I had a similar issue but i was smelling it inside and especially when i got out of the cab, mine was the fuel lines on the driver side of the motor had come loose, mechanic said he just had to replace a o-ring on one of the lines and the other just needed to be tightened up.
Old 01-20-2012, 08:56 PM
zhilton's Avatar
zhilton
zhilton is offline
You know, I'm not saying you need to tear the bead off your truck...but I wonder if you have a fuel line leaking somewhere around the tank to HFCM? Could smell like raw fuel near the tailpipe if the wind was blowing the right way.
Old 01-22-2014, 07:08 AM
surfmanrescue's Avatar
surfmanrescue
surfmanrescue is offline
did you ever figure out what was going with the exhaust smell?
Old 01-22-2014, 04:47 PM
98SurplusExpy
Not specifically; but, about 10-mos after this post I identified a raw-diesel leak at my fuel pressure regulator. I replaced the housing & gasket (did the blue-spring mod) and the odor diminished mostly.
I can still smell diesel exhaust when running ... I've mostly attributed it to just being the nature of the beast.
milkmantx
2017+ Super Duty
45
02-21-2022 11:50 PM
fords/harleys
10-08-2018 04:58 PM
90pioneer
6.7L Power Stroke Diesel
15
12-01-2015 09:10 AM
zmock8
02-22-2014 02:47 PM
yukonsly
02-05-2006 06:36 PM
Quick Reply: Stong smell of unburned diesel from exhaust (not inside the cab)
