84 F250 oil pressure gauge.
My 84 F250 the oil gauge doesn't work, never has that I remember. Pulled the intake off, it doesn't have an oil pressure sensor on it. I assume my dad plugged the hole when he took the banks turbo off of it b/c he didn't realize what it was. But also while I was there I was going to check the EGR vavle on the back, I took that off and noticed another small hole in the valley pan behind it. The EGR valve looks different than all the other ones I've ever seen, and this other hole makes no sense. My 88 Ford and my 86 Ford neither one have additional hole in the valley pan I can find, and the EGR valve looks different than the one on the 84. Is this because its an 84 or something to do with the banks turbo that was on it? Also I'm assuming that the round thing behind the intake manifold is the EGR valve, I'm not sure though so if I'm calling it wrong tell me.
if we r talking about the same thing it is called a CDR valve similar job to PCV valve
Redirect Notice
i know its a long link but i cant seem to post pics yet see if this is what it looks like
this link is a good pic and explanation of how it works
the turbo would of drained its oil back into the engine through the valley pan and CDR would of been relocated to the valve cover when the turbo was on the engine
Redirect Notice
Redirect Notice
Redirect Notice
Mine no longer has a turbo on it. There is a hole between the CDR hole and the bell housing that had a plug plug in it that a 3/8" ratchet took out. It looked like it had been drilled out for something and thats where the oil was coming from. I decided since it didn't have any oil pressure on it, I just filled the hole with silicone gasket maker and I think that should fix the problem. My oil pressure sensor hole had a pipe plug in it so I put one on it and I think its fixed now.
Twilight Fenrir
11-05-2013 05:21 AM
snaponprofile
01-28-2013 06:40 AM
