1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Need help with wheels
Old 01-14-2012, 01:10 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
I am looking to buy some new wheels. I am looking at these Gear Alloy Backcountry wheels (see pics). I know nothing about wheels. What kind of dimension information do I need? I know they are 8 lug (duh), but offset, backspacing, all that I do not understand. What do I need?
Old 01-14-2012, 01:20 PM
acf6's Avatar
acf6
acf6 is offline
well you need 8x170mm bolt pattern and thats about all i can tell you. Subscribing because i would like to know the same stuff
Old 01-14-2012, 02:54 PM
bpounds's Avatar
bpounds
bpounds is online now
Trey, are you looking at the 18" or the 20"? The 719MB is available in both, and both are 9"wide. Your OEM wheels are only 7" wide.
You need 8x170mm as noted above.
Offset is the distance from the mounting face to the centerline of the wheel. Your stock OEM wheel has a .25" offset, meaning it mounts almost on the centerline. An offset spec should include a "+" or "-" for positive or negative, but the Ford spec doesn't mention which it is. But at only 1/4", it isn't of much matter.
Backspace is the distance from the mounting face to the inside bead flange. Those Gear wheels have a 5" backspace and a 0" offset. You can pull a wheel and do some measuring on your truck to see if the will clear. I think they are meant for the early SD like yours, because that is far too much backspace for the '05 and up SD. But of course it depends on the tire you mount.
I would call them and ask. I'm sure they get asked that same question every day. Also ask them the weight rating. Their specs leave a lot to be desired for information.
Edit: I found this spec page.
719MB
It notes which models fit the "older" trucks.
Old 01-14-2012, 06:16 PM
dscabra's Avatar
dscabra
dscabra is offline
This link might help:
Wheel Offsets - Discount Tire
Old 01-14-2012, 09:37 PM
Benny76's Avatar
Benny76
Benny76 is offline
Depending on what size tire you want to go with you can probably find a good set of factory 05 up FX4 wheels. They are 18x8. But the biggest recommended width you can go with is a 295 on an 8" wheel. That's why I went with the Nittos, only one of 2 tires you can get in a 295/70/18. They are 34.5" tall which is as big as I wan't to go with anyway because I pull a camper. But anything over a 295 it's recommended from most manufactures to at least have a 9" wheel. I didn't want aftermarket wheels because I like the factory center caps as goofy as that is. So the widest I could go was a 295. When the wheels get ugly I'll prob go with a 10" wheel so I can go to a 315 width. As BP mentioned make sure the weight rating is up to par. He is absolutely right about that in my opinion. Big truck + E Range tires + wimpy wheels = dumbness.
bobbytnm
28
11-16-2018 07:46 PM
Planejet42
07-22-2015 01:40 AM
Garrett248
06-13-2014 07:22 PM
animaldawg
02-04-2014 02:53 PM
Brian129
02-27-2012 05:25 AM
Quick Reply: Need help with wheels
