6.2L V8 Discuss the 6.2L V8
Just about to order a 2012 Chassie Cab 6.2
Old 03-02-2012, 11:31 PM
07sbock's Avatar
07sbock
07sbock is offline
Question Just about to order a 2012 Chassie Cab 6.2
I am very close to putting the order in for a brand spankin new 2012 F350 Extended Cab XLT DRW Chassie with the 6.2, But I have a few questions?
(First new truck I ever have purchased) I have never wanted to take the hit new but when they give you what you paid for your old truck you cant say no!
Should I get the 3.37's or 4.10's?
Its going to have a dump body on it and be towing/hauling every day and plowing snow in the winter with occasional interstate travel, what do you guys think?
Im upgrading from a 08 V10 chassie with the same specs. Can I expect an increase in milage, have you guys run E85 in them with any plus sides?
Is the sync system worth it?
Anything else I should be looking out for or things I should be aware of!
I wanted to go with the 6.7 but its too expensive! I plan on turning this thing back in at 60-100K for a new one. Maybe the next will be a diesel.
I was pretty impressed with the get up and go from the 6.2
Thanks in advance! Ill throw some pics up once she get upfitted in 9 weeks
Old 03-03-2012, 10:58 AM
nico963's Avatar
nico963
nico963 is offline
4.10 isn't an option,4.30's is....
With your use of the truck...No doubt 4.30's.
Old 03-03-2012, 11:19 AM
stutzismydog's Avatar
stutzismydog
stutzismydog is offline
You ask about is the "sync system worth it?" I will say defiantly " yes " and particularly for you because of the amount of time you are working in that rig,....give your self a little pleasure to make your day.
Old 03-03-2012, 02:55 PM
07sbock's Avatar
07sbock
07sbock is offline
I figured it was nice, Just not sure about the price tag! Still torn on the whole gear ratio thing. Are the 3.73's going to be fine or am I looking into it too much.
Old 03-03-2012, 03:35 PM
stutzismydog
I would think that under the conditions that you outlined,...primarily a WORKING TRUCK, you should go with the 4.30 gear ratio and expect to loose 1 to 2 MPG at highway speeds over the 3.73 millage but you would probably break even if you are working the truck and using the 6 speed transmission in the lower gears if you had the 3.73 verses the higher transmission gears with the 4.30,....so your call but I would go with the 4,30 and you will probably still get better overall millage than your current V !0 and have more power.
Old 03-03-2012, 04:21 PM
fg250's Avatar
fg250
fg250 is offline
I would go with the 4.30 gears, you'll have plenty of power with those.
Old 03-07-2012, 05:15 AM
kbhblazer's Avatar
kbhblazer
kbhblazer is offline
I bought a 2011 cab and chassis, I'm glad I went with the 4:30 gears
Old 03-07-2012, 07:20 PM
erics218's Avatar
erics218
erics218 is offline
Here's my 2 cents. I ordered the 4.30 gears for my F350 to maximize the power. It sounds like guys with the 3.73 gears are having to run in 5th gear at a higher rpm while towing. I thought with the lower gears it would be able to stay in 6th gears running at a lower rpm to increase fuel economy. I will soon find out, it sounds like I should get it in 3 weeks.
ngamountains
2017+ Super Duty
11-10-2017 03:02 PM
gilby959798
6.7L Power Stroke Diesel
37
05-07-2012 07:53 PM
Ricohman
Modular V10 (6.8l)
19
11-18-2006 04:00 PM
trcklvngrl
1999 to 2016 Super Duty
17
03-05-2001 07:57 PM
Quick Reply: Just about to order a 2012 Chassie Cab 6.2
