Exhaust Manifolds 60 Ford
Old 01-12-2012, 09:33 PM
fireball14513's Avatar
fireball14513
fireball14513 is offline
I would like to put dual exhaust on my 60 Ford F100 it has the stock single exhaust on the 292 3 on the tree...What are some options I have?
Headers,ram horns or is there another exhaust manifold that I could use? Also will some of these options block me from working on the engine itself...Any help would be great Thanks Mark
PS more questions will be coming as start my project...
Old 01-13-2012, 12:48 AM
tbirdscott's Avatar
tbirdscott
tbirdscott is offline
Might want to ask in the y-block engine section. Dont see too many people modifying the y-block here. Whatever you do it couldnt make burning yourself any easier compared to the stock crossover pipe!
You looking for more performance or more sound?
Scott
Old 01-13-2012, 07:28 AM
ibuzzard's Avatar
ibuzzard
ibuzzard is offline
Panties NOT in a Twist
As you stated - Ram horns, headers, or as was frequently done ,use two right-hand manifolds,capping the holes for the cross-over tube.This leaves the exit facing the front of the truck on the drivers side.Then have an exhaust shop bend a sweeping "goose-neck" bend to wrap down, under,and towards the rear.It works,though it's a bit hillbilly to me.I could never bring myself to do that,and waited till I had the money for headers,then ramhorns.Oh,wait, - aren't about 90% of us Hillbillies?In that case, you may be good to go........LOL
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Find a 1955/57 Ford or Thunderbird with dual exhausts, get the manifolds from it. All the Birds had duals, optional on the Fords.
Try: Big M Automotive in Williams CA.
Old 01-13-2012, 09:12 AM
59flatbedford's Avatar
59flatbedford
59flatbedford is offline
I thought the T-Bird manifolds wouldn't clear on our trucks. Im not sure where i read that but something about the steering box or the frame or something. Maybe it only applies to 4x4s. Im planning on running Rams Horns on mine since last i check they were being offered aftermarket and would last longer than headers.
Old 01-13-2012, 12:04 PM
tbirdscott's Avatar
tbirdscott
All stock suspension and it cleared
Truck belongs to a friend of a friend, 57 merc shorty, t-bird 312.
Scott
Old 01-13-2012, 12:48 PM
59flatbedford
hmm those look like rams horns. I guess the T-birds might have came with Rams Horn and the manifolds i was thinking of are the passenger car ones. Not sure ill have to do some looking.
Old 01-13-2012, 12:53 PM
NumberDummy
Only trucks were available with Rams Horn manifolds, they were not offered for Passenger Cars including Birds.
Old 01-15-2012, 12:32 PM
F250racer's Avatar
F250racer
F250racer is offline
I used a set of reds longtube headers. They fit fine, only issue is they cover the spark plugs, so I'd recomend changing plugs when you put the headers on. Even so, it really isn't a big deal to loosen the headers to change plugs.
Here's the best pics of it I could find.
Old 01-21-2012, 09:26 AM
fireball14513
I think Ill go with the ran horns Thanks for the help Mark
Old 01-21-2012, 09:37 AM
ibuzzard's Avatar
ibuzzard
ibuzzard is offline
The ram heads will be a good choice.Unlike many reproductions,the quality is there.
I ended up finally using the hardware from these guys,they were nearby,friendly and top quality:
http://www.stage8.com/index.html
A direct phone call got me just the exact length needed, one not available at that time, in the kits sold through retailers.They sent them out the morning I ordered them,had them in-hand the next day.
Old 01-08-2013, 12:55 PM
msauls's Avatar
msauls
msauls is offline
This thread is a bit old, but was wondering if anyone had any clarification on these statements (below)? There wasn't a definitive answer/reply.
Will the 55/57 Tbird exh manifolds fit without interference on a 272 F100?
...or any stock passenger Y-block for that matter. I'd like to keep the stock look for my F100 without the crossover pipe.
Find a 1955/57 Ford or Thunderbird with dual exhausts, get the manifolds from it. ....
I thought the T-Bird manifolds wouldn't clear on our trucks. Im not sure where i read that but something about the steering box or the frame or something.....
tomtomterrific
09-09-2013 01:02 PM
Ki-Adi-Mundi
24
04-08-2013 06:33 AM
pmh
16
12-06-2012 06:22 AM
Narwhal
05-26-2004 08:53 AM
Quick Reply: Exhaust Manifolds 60 Ford
