why would you remove a safty device that should help prevent a possible runaway engine on that is know to overfill the crankcase and pump oil back in for reburn?
My Tuner does delete the egr valve, but not the throttle
Plate motor in the intake elbow that I removed.
I sent it back to Gear Box Z for them to re-program
It to delete the throttle control code P0488 with No
Success :-(
I'm gonna call them back ....
If u got the wrench your proably gonna end up with your truck going into limp mode after awhile, thats wat mine did tell i got the right spartan tunning im guessing ur cruise proably dosent work ither. Best to put it back tell u get the right tunning
I never saw a 6.4 set up. The throttle body is between the intake manifold and the elbow. one side has a plug that goes to a motor that opens and closes the butterfly 3 wires and the otherside has a ?position sensor with 2 wires. I havent set up a way to download pictures yet I can try to do that this weekend. What set up does the 6.4 have?
The EGR Valve & air flap motor (don't kno proper name) is all in the the stock intake elbow assy on my 6.4L, that I removed & installed the billet alum Aftermarket unit
