trying to figure out battery draw issue, gem module question.
I thought I read somewhere on the forum that it was 15 minutes. Let me search around.
I believe the drain is less than 25milliamps when it goes to sleep. Check what your drain is now and check it again in 15 or so, the 20 or 30. If its lower you know if went to sleep. If it never changes then its staying active and could be why you are having a drain.
nookiemonster55
08-30-2013 10:32 PM
